buying a truck from a non truck person
Discussion in 'The Garage' started by 55Willy, Feb 18, 2007.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    found a 76 k20, is it a 44 or a 10 bolt and would it have flat tops?
    4" lift 350-350-203 37's with 4.10's
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    flat tops on Dana 44 only. I think the cut off for flat top D44's was '75
  3. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    It should be a D44 with flat top knuckles, but depending on the history of the truck a different year front axle could have found it's way in there.
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I forget the rule of thumb for D44 vs. 10 bolt placement, but I have seen several 1980 1/2 and 3/4 tons with D44's up front. GM would use whatever they had on hand. Only SUREFIRE way is to go look.
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I have seen flat tops on 10 bolts. A friend of mine had them on a 1987 10 bolt. He bought the truck in stock trim so I doubt someone swapped them. Go look under the truck
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    :confused::confused::confused: Id be willing to bet someone broke a knuckle or you didnt know what you were looking at. No stock 10 bolts came with flat tops
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    '76 will have the flat tops. This year is the "first design" axle. The "second design" started in mid-'70.
    10 bolts are "second design" also. You won't see them in '76 unless it was swapped in.
    Another 'plus' is the D44 in the K20's have 1/2" thick tubes pressed into the pumpkin and outer C's.
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    so it'll be worth the $1000 to go check it out.
  9. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    If it's in good running condition, most definitely!
