buying extended brake lines???
Discussion in 'The Garage' started by purple76pearl, Jan 17, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    when i purchase my brake lines to put on my 6 inch lift, is thee only one set you can get, or how long of lines do i need to purchase, who makes the best brake lines, or are they all the same? /forums/images/graemlins/k5.gif
  2. CK5
    May 19, 1999
    21,627
    704
    CO
    I will be having some 34" long ones made as well as longer rear ones, I will have more info in a few weeks.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I made those for the Sub by calling Orme Bros and ordering the bits to make them.
    One thing about pre-made -3 hoses is that they have 2 very weak points in them, one right at the fitting end of each crimp sleave. If you go with pre-made hoses buy those that have a std -3 end on them and use adapters, then carry a couple screw together hose ends. If you break the end off of a pre-made with dedicated ends on it there isn't much you can do in the way of a trailside repair.
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    check to see if stock lines off a van will be long enough, i know guys have used them with 4" lifts, i guess it depends on the amount of flex you have.
