bypass oil cooler
Discussion in 'The Garage' started by dheavychevy38, Dec 25, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Whats the best way to bypass the oil cooler on a 91 jimmy fullsize cause when my bumper got ripped off some how the cooler got destroyed and i did a trail patch but on the way home the hose broke and i lost a;;; of the oil. Any other good ways i can bypass it for the time being supposed to go play on the 26th. Thanks Denny
  2. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    dont really know how to bypass it when mine busted i went and got a cheap tranny cooler and put it on there until i got a new oil cooler, thats what i did anyway. sure someone knows how to bypass it GOOD LUCK!
  3. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    remove the stock oil filter adapter and put a normal one on there that doesn't have provisions for an oil cooler.
  4. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    like above .
    remove oil filter.
    remove 2 long allen head bolts.
    remove filter/cooler adaptor.
    remove and install new oil filter adaptor gasket.
    install filter adaptor from non cooler motor with the 2 short bolts.
    install filter and run motor and check for leaks.
  5. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Do you need to keep the cooler for any real reason because mine is going to be in the way of my new winch?
  6. sweetk30
    Nov 1, 2004
    25,539
    538
    i have run a built 400sbc with and with out one. no real drop in temp i could see. if lots of heavy towing yes i would.
  7. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    sweet i guess all i have to do is pull the adapter from my other motor and bolt it on thanks guys
  8. sweetk30
    Nov 1, 2004
    25,539
    538
    dont forget there is a gasket under the adaptor to block.
  9. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I just pulled an oil cooler from the '89 sub I'm parting out. PM me if you want it. Its in good shape, would need to be cleaned out before you use it though. The block cracked and pumped some coolant into the oil.
