Bypassing heater core???
Discussion in 'The Garage' started by stallion85, Mar 16, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I pulled all of my HVAC equipment out of the truck today. I have a question, is there anything wrong with plugging up the waterpump and intake manifold where the heater hoses used to be?
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I lost a heater core on the trail in August and just ran the intake hose to the waterpump "spot", effectively bypassing the core - no problems arose from it. AFIAK there should be no ill effects to do that.
    I did put a new core in before winter because it gets too friggin cold up here not to :)
  3. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    My heater core was leakin so I just bypassed it. You can get a coupler from the parts store made to connect the heater hoses together cause they are diffrent sizes.
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    So I can't just plug the holes? I am not going to be reinstalling any of the HVAC stuff.
    What I want to do is plug both of those hole to where no fluid will travel from the pump to the top of the intake.
    Everything as far as coolant system should still operate properly?
  5. ballu_one
    ballu_one Registered Member
    Mar 13, 2006
    20
    ont. canada
    hey thats ok , do u realy need heat , well if not just drive it its not like u are out of town if it blows right> and if u are just get a aaa card they will tow u home just site back and look at your ride and say thats mine and its fast
  6. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    It should be just fine. I don't have any of that stuff hooked up in the buggy and it seems to operate well. We just plugged everything.
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    yes you can plug them, there are some steel plugs sold out there that just screw into the holes, just like the ones installed in some water pumps to plug that hole. They will either have a square top to them so you can grab it with a crescent wrench, or sunk in with a Allen wrench type setup.
  8. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    those are npt plugs. pull the hose barbs off the waterpump and manifold and bring them to a hardware store. just match up the threads with the correct plugs. i think its 1/2" and 3/4" npt
  9. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Cool, thanks guys. Just so you all know my rig is no longer street worthy so she gets towed everywhere, no doors or top.
    The heater wasn't doing much in the first place....lol.
  10. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Or you could run a heater hose between the water pump and intake manifold. you would just be looping the coolant back through the system.
