Bypassing The Steering Box With Hydroboost.
Discussion in 'The Garage' started by dhdescender, Apr 11, 2004.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I need to bypass my steering box from the Hydroboost lines. Heres a picture of how the system works:
    Do I simply cap off the high pressure line coming off the booster as in this pic:
    I'm going to have my stock Caddilac pump drive my Hydro assist steering, and use the stock hydroboost pump soley for braking duties.
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I wouldn't know of any reason that wouldn't work. Never messed around too much with my hydro boost but it seems that is all that would be necessary.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I would say the line you capped would have to go as another return line to the reservior or the pump will put full pressure against it
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep, you have to run that line to the resevoir as a 2nd return as MJ said. Thats the way mine is setup and it works just dandy.
