C-clip eliminater kit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tice, Jan 6, 2003.
  1. Tice
    Tice Registered Member
    Aug 24, 2002
    36
    southeastern arizona
    I wanna get rid of the c-clips in my 12 bolt but can't find a kit and the warn full floater kit is to much. Anyone know where to get one? Thanks. Tice
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Look in Summit or Jegs, they have them. I believe both Currie and Strange make them, along with others I'm sure. They tend to leak, not exactly a great product for anything but a drag car... /forums/images/graemlins/tongue.gif
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I have heard the same thing about them leaking and they work good in a drag race car. Any other inputs?????
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I looked into these when I was building up my 12 bolt (my first mistake), and everything that I read and everyone that I talked to said that the c-clip eliminators are NOT designed for off-road use. They are strictly for drag racing. They cannot take sideloads and will break if you inflict it on them.</font color>
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Best, safest, most durable and cost-effective c-clip eliminator =
    14BFF!
    I know, I know. But, quite honestly, that is the true answer. Ponder it.
  6. four_by_nut
    four_by_nut Registered Member
    Jan 7, 2003
    10
    Phoenix, Arizona
    OK. Let me start by saying I drive something that looks like a #eep, but has all Chevy innards. I run a 12bolt with the C-clip eliminators and 38" tires. I wheel it pretty hard off road (not high speeds. I only do low speed rock crawling). I haven't had a problem with side loads breaking them. But I also only weigh about 3,500 lbs.
    I DO have issues with them leaking. About every 6-8 months I have to replace the inner seal and regrease the bearing. It doesn't come pouring out when it leaks. It just dribbles a little, washes the grease out of the bearing and gets on my brakes. I know they are leaking when my brakes get a little sticky as they warm up.
    I went with c-clip eliminators due to cost reasons. I plan to go FF in the next year or 2. I didn't go 14 bolt because of it's MASSIVE size and weight. 12 bolt is holding up fine for my needs.
    Just my insight if it helps at all.
  7. dyeager535
    26,980
    Only thing I've ever heard about these things is that they leak, and most of the posts here prove it. Bad idea, changing the brake shoes all the time gets to be a chore.
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I had a link for the Moser engineering C clip eliminator kit for the 12bolt.
    It costs unders $200 and it requires turning down the axle shaft end to size to fit the kit.
    I didn't particularly like that part.
    I wish warn still did their full floater kit, I really wanted to have one.
  9. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    yes i also used the 14 boltff c-clip eleminator kit.works great!i'm a satisfied customer.mine even came with new rims. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  10. ABO
    ABO Registered Member
    Jan 16, 2001
    77
    The Burgh
    Join the Club...pavment pounders kick arse!
