c-clip eliminator for 9.5" 14 bolt?
Discussion in 'OffRoad Design' started by muddysub, Jan 5, 2002.
  1. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    c-clip eliminator for 9.5\" 14 bolt?
    does anyone make one of these? i've seen kits for other axles but not a 14b-sf.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: c-clip eliminator for 9.5\" 14 bolt?
    C clip eliminators are crappy for the street and NOT meant for the side loading of off roading.
    You've already got an 8 lug frontend--just get a full floater.
    I have a semi floating 14 and I've never had any problem with it at all.
    I have seen 12 bolt rears hold up to 44s for WAY too long to worry about C-clips.
    I'm going to a full floater only for an easy-install Detroit. If my SF 14 was open, I'd just get a lock-right and keep it.
    Tim
  3. muddysub
    Jun 23, 2001
    10,454
    493
    cool, i didn't really know what a c-clip eliminator was, but now i know i don't need one. thanks
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Yea, they really are meant for drag race use only. If you run bias plies and keep them aired up you can go for a while before they start leaking.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  5. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    If you run rear disc brakes... if a clip breaks, least those keep everything inside.....
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I'm in shape.... round is a shape......
  6. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    With a 33 spline axleshaft, I wouldn't worry too much about the c-clip. They commonly hold together really well till you break the shaft so it should be fine.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Matt (Baby Blue) just broke his 14sf driving it around town after we went wheel'n. He broke the center pin which caused the axle to start to walk its way out. The biggest bummer is that it was a friends...he is going to see if he will take a 14ff in return. Still I wouldn't worry about it if you drive sainly (Matt does not!).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
