C clip eliminators
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevBlazin, Mar 18, 2002.
  1. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I was looking through a Jegs catalog recently. I saw they sell something called C-clip eliminators. it bolts on to the end of the axle housing and has bearings that are pressed on to the axle shaft. If the shaft breaks it wont slide out of the housing. Has anyone used these on a 4x4, or wouldnt they hold up? Maybe something similar could be done with 4x4's?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Don't bother. They don't last for street use, let alone offroad use. DesertDueler has installed a couple sets on cars, and he said every set came back to him with leaks.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Yea what Harley said /forums/images/icons/smile.gif The only one I have seen hold up for a while,was on a really light mustang and he runs M/T Sportsman Pros on the street. They are wrinkle wall two ply sidewall. He also has to run them at 20 psi whick makes you drive on the center. He still has to replace the seals about once a year, and he doesnt drive it much at all either (drag car). And if the axle breaks at the end you are still screwed.
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Just get some disc brakes and the shafts won't shoot out then! /forums/images/icons/smile.gif
  5. ChevBlazin
    Feb 4, 2002
    332
    yeah, I was thinking about the disc brake thing. Not a full floater, but it sure could save you.
