C clip Q's
Discussion in 'The Garage' started by southernspeed, Dec 21, 2004.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Who runs C clip axles with an eliminater? Is it worth doing and what exactly is a C clip eliminater? Any advice greatly appreciated.:waytogo:
    What do you reckon TIM? chance of a sale here!!:D
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    You dont want to run a c-clip eliminator kit on an off-road vehicle. The bearing size decreases with the kit and it wasn't designed for the sideloads of off-roading. They're only meant for drag racing.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Cool, that's all I need to hear. Thanks.:xmas:
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Aytime. No problem.. I've heard of people(and have myself) breaking axles, but have never heard of a problem with a C-Clip itself.
  5. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    I had an axle where the C-clip groove had opened up by about 40 thou due to wear. That minute amount was enough for the c-clip to be able to drop out and then I almost lost the damn axle.
    That was on a 7.625" 10 bolt.
    I ended up making a thin shim that went in the groove with the C-clip.
    Rene
  6. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    This site amazes me!
    This site always amazes me. There is sure a vast range of experiences here that it seems like if there is something that can possible go wrong, someone here has experienced it. No matter how obscure or unlikely the problem seems.
    :xmas:
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I would think you can cheat a little and keep the shaft in long enough to make it back to the trailhead if you use rear disc brakes , since the rotor is attached to axle end and held in the caliper . I intend to someday :xmas:
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Years ago when I was stilling running a 10B rear I looked into the eliminator kits. Most places, even the companies who make them, didn't recommend them for off-roading or even daily driving.
    The only purpose of the c-clip eliminator is to keep the tire and wheel from flying off into the stands at a drag race. You cannot drive the vehicle on the road safely, or any type of distance at all before it would chew up the wheel bearing and let the tire and wheel come off anyway. I've personally seen a flanged Dana 44 rear completely axle chuck a tire and wheel on the road after a shaft broke when the bearing finally let go.
  9. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    This dones work ok, I run disc's on my 12b and once broke a rear shaft and was able to drive back up to a main road. The caliper will keep the axle on. It's better than having to strap a log to the tire to keep it in!
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    14ff solves all those problems. :grin:
