C clips
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snowtoy, May 8, 2001.
  1. snowtoy
    snowtoy Registered Member
    Mar 18, 2001
    30
    Norway
    My neighboor use to have a suburban with c clips axles, he told me he have to changes them every year (16000 miles)!
    Is this realy necessary? do I have to changes them before a long trip?
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    He's got something wrong with his rig if he has to replace them every 16k.
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I really never considered a c-clip to be a maintenance item. There is really no wear on the c-clips so I don't see why you would need to ever change them.
    The 10-bolt (c-clip axle) in my '90 had over 100,000 miles with no problems with the original c-clips. In fact, I had the internals completely rebuilt (4.10 gears, aftermarket limited slip, etc.) at about 75,000 miles and re-used the original c-clips.
  4. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Change the c-clips in the axles? Shouldn't have to un less you start to get excessive play which should take years. Change the gear lube when required and thats about it.
