C++ programming
Discussion in 'The Lounge' started by 84gmcjimmy, Aug 11, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have a couple questions regarding C++...
    I played with it a bit at school for 1 semester in a computers class, but haven't taken it since.
    If I were to find a cheap version to buy or a simular program, would I beable to make programs and such, for example:
    When the computer starts up, a window (that I made) pops up, and tells me I'm a sexy beast?
    Or something that converts celcius to farenheit by putting the celcius in, then getting the farenhiet?
    Or when someone clicks on a program (mozilla for example) a window pops up and asks for a password first before it can open? Is this what I can do? Or is my memory fogged?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Just about any programming language can do those tasks (though I wouldn't choose Fortran.....), don't particularly need C++. My first thot is the Visual Basic would be the easiest, unless you're very proficient in C++
    For a units conversion utility, search for "Convert.exe" It is the simplest and easiest to use conversion program I've ever used. I tried zipping and attaching it, but it's still a little too big.
  3. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    If you want to pop up windows then you probably should use something like VB or any .NET language. It really boils down to what IDE / compiler do you have available to you. If you just want to write a conversion program, you can do that without a window and just run it in a cmd window. Then C++ would be almost as easy as any other choice.
    I might be able to help you out if you need any development environments... Let me know what you want.
    Scott
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    What would be the best one for what I'm after/? I don't know the retail price on any of them, maybe they'd be cheaper on ebay or something.
    I want something I can expand on later, like make bigger progams once I am used to it.
    Suggestions? I just asked about C++ because thats all I know/knew how to use.
  5. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    If you want to write stuff for windows, get Microsoft Visual Studio. It is expensive, but if you are a student, you can get a really good discount on it. It will allow you to use any .NET managed language (C++, C#, Visual Basic, J#) to write windows programs. It really makes it easy.
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I don't know if you can use C++ for your operating programs on the computer like a pop up window when you turn on your computer, or when you open up a program..
    converting celcius to farenheit, yep i could write a c++ program for that kind of stuff.. c++ is good for user inputs to get an output, or creating loops, mathematical problems, random number generaters... etc...
    I had a hell of a time in my class studied my ass off worked hard, tried to collaborate with classmates, but its also a bad idea because its easy to see if you are copying someones program, or working together when theres 1000 different ways to write it! I thought i was borderline for passing my C++ class but i got a B. :rotfl:
    If you need help or questions on c++ you can try me, though i know theres a few guys on here way smarter than myself with this program..
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Ryan, so C++ wouldn't be my best option then? Can you suggest another program? Or do you only use C++?
