C vs. J code oil filters
Discussion in '1982-Present GM Diesel' started by schlechto, Jul 28, 2002.
  1. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    I went to get a new oil filter and I saw that there were two kinds, what is the difference in the filters, I know the differences in the engines, but the oil filters appear identical only with different codes
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Just a guess; but maybe one has the anti-drain back valve in it (the other doesn't). Later styles (6.5) with oil cooler and turbo need the anti-drain valve for start up.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Dan is right. That's the only difference. It's the same thing with gassers depending on how the filter is oriented on the engine. If the filter sits at the bottom of the block the anti-drainback filter is unneccesary, but if it's on the side of the block the anit- drainback valve is needed to keep oil in the filter for start-up.
  4. schlechto
    Aug 4, 2001
    56
    Carnation, WA
    Thanks guys /forums/images/icons/smile.gif
