C20 vs K20 calipers, the same?
Discussion in 'The Garage' started by AussieK5, Dec 15, 2005.
  1. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Ive done some digging around before I order the parts for a rear disc conversion but cant find any reference to the interchangebility of the 3/4 Ton C20 and K20 (D44) calipers. C20 calipers are plentiful, K20 calipers need to shipped half way round the world. Are they the same calipers or can either be used for the conversion? TIA Jason
  2. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    They are different, or at least have different part numbers at the one place I looked 'em up at online. I don't know whether the 2WD calipers can be used for the disc conversion though.
    -- A
  3. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Thanks, thats confirmed what I thought.....damn damn double damn!!!!
    cheers
    Jason
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I know for sure the angle that the brake line connects to the caliper is different. I don't know if it will physically bolt in place of a K20 caliper or not, but I would guess no.
  5. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I took a pair of calipers and brakelines off a '73 1/2 ton 2wd and used them on a Dana 44 3/4 ton front axle. The brakelines and fittings where they bolt to the calipers are different. But I used the 2wd brakelines too along with the calipers, and they actually gave me an extra inch or two of length for lift. The other end of the lines bolted up to the existing hard lines on the truck.
    So as far as dimensions go, they will work, but only if you use the 2wd brake lines as well.
  6. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Thats great info as I most probably will be getting the lines made up locally.
    Thanks guys
    Jason
  7. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
