CA Emmisions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CrazeeBush, Apr 22, 2000.
  1. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    I have a 1983 K5, and I was just curious as how to identify one with CA Emmisions. Just curious.
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    There should be a sticker in the engine compartment identifiying either Federal or California. The Vin# should also show this information.
  3. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    What is in the VIN# that shows CA Emmisions?
  4. Waxer
    1,857
    Long Beach, CA.
    It will show if the K5 is either a Federal, or California emission controlled vehicle.
  5. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I am sitting here looking at the VIN number breakdown in both my owners manual and the Chiltons manual, and neither stipulate anything about emissions. The Chiltons manual does however, show vacuum diagrams from under the hood that do tell you what your emissions are set for from the factory.
    My 86 has a code of YDW which says it is a 305 with a 4bbl high and low altitude and export with an automatic transmission alternate. The export meaning it is not meant for Calif. The same year if it had a code of YFN it says it is a 4bbl California low altitude with auto transmission.
    Now for the VIN, in 1981 they changed to a 17 digit number as follows...
    1GCEC14D9BF123456
    first digit: Nation of Origin 1=USA 2=Canada
    2nd digit : Manufacturer G=GM
    3rd digit : Make and type A bus (van) B=incomplete vehicle C=truck 8=multi purpose vehicle
    4th digit : GVWR/Brake System B= 3001-4000 C= 4001-5000(and so on)
    5th digit : Line and chassis type C= conventional cab 4x2
    K= conventional cab 4x4
    P= forward control chassis 4x2
    G= van, sport & cutaway 4x2
    w= Elcamino 4x2
    6th digit : Truck series 1=1/2 ton 2=3/4 3=1 ton
    7th digit : Truck body type
    0=sedan pickup
    1=hi cube cutaway
    2=forward control
    3=4 door cab
    4=2 door cab
    5=van
    6=surburpan
    7=motor home
    8=Blazer
    9=stake platform
    8th digit : Engine and codes G=305 2bbl
    F,H=4bbl 305
    L,M,P=4bbl 350
    W=4bbl 454
    Z=5.7 Diesel
    9th digit : is a check digit (?)
    10th digit : Is the yearcode B=81 through M=91 inclusive
    11th digit : is for the plant location...(ex..F=Flint)
    12-17 digits: is the plant sequential number.
    The preceeding is from the Chiltons Manual for Full Size Chevy Trucks 80-87
  6. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    I didn't think the VIN # gave anything away about Emissions or not, b/c I was looking at that same breakdown. What about the emmision label under the hood, it there anything on there that SPECIFICALLY says "CA Emmisions"?? I did notice this note at the very bottom of my sticker.
    "THIS VEHICLE CONFORMS TO U.S. EPA REGULATIONS APPLICABLE TO 1983 MODEL YEAR NEW LIGHT-DUTY TRUCKS."
    Does that mean anything?
  7. Waxer
    1,857
    Long Beach, CA.
    ok, I knew that the vin was questionable, so I am wrong with that one. On my 74 K5, there is a sticker in the engine compartment that shows it to be a California Emission vehicle as opposed to being a Federal.
  8. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    he tag under he hood should have a code on it, again mine has a YDW. This is in the upper right hand corner of the sticker. The code on yours will tell you what the emissions were set for.
    <font color=green>[​IMG]Eagle86K5[​IMG]
  9. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    Top Left corner has "DFH" in big letters, is that the code?
  10. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    That is the code, my book does not really start covering all the codes till 1984, so I cannot tell you for sure what you want to know except that is the code . You might call a GM dealer and they can tell you or some else might know where to call....
