Cab and chassis 14bolt, can I put the DRW hubs on a 3/4ton 14bolt
Discussion in 'The Garage' started by jjlaughner, May 16, 2006.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I know the 14bolt C&C is narrower, can I put the DRW hubs on a std 14bff from a 3/4ton (I have one thats already shaved and the perches are int he right place, plus the C&C is to narrow).
    Anyone done this? Pics? Widths? About the same as a DRW front D60?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    IIRC the hubs are the same, the housing itself is different.
    http://www.pirate4x4.com/tech/billavista/14b_bible/index.html
    apparently not, the hubs are different. according to the illustrations, installing your C&C hubs on a SRW axle would just make it into a C&C axle, now with 1/2 and 3/4 ton spring spacing.
  3. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Well, yes, but.
    The hubs will fit; they are identical to the wide dually hubs. The only difference between dually and SRW hubs is that the WMS is in 2" on each side.
    HOWEVER ... this means the drums won't fit, unless you move the backing plates by cutting the flanges and re-welding them :(
    -- A
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    might be best to talk to Tyler from Ill (cant recall his logon, BlueBlazer6.2 comes to mind), he's got my old C&C axle, and had some plans for it.
