Cab/clearance lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crashfirepm53, Mar 14, 2004.
  1. crashfirepm53
    crashfirepm53 Registered Member
    Mar 14, 2004
    62
    florida
    While my headliner is down getting replaced , I'm going to add Cab lights.Did a search but I cannot find a previous post on it(I know ones there).Anyways, where is the best place to tie the wiring into the truck?Wire colors of the correct ones?Any good places to find a nice selection of clearance lights?? Anyone have the LED lights? Anything diff. required for these??THanks.
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    It may be easier to wire them to a switch (or switch and relay) than to tie into the marker lights (which I assume would be the one you want)
    LED's I THINK are just brighter and more expensive
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    My 87 came with aftermarket lights mounted on it. They are made by "Pacer". Typical teardrop design. They are grounded through the mounting screws and have 1 power lead than was run up the A pillar and spliced into the headlamp switch wiring.
  4. crashfirepm53
    Mar 14, 2004
    62
    florida
    You don't which color wire it is do you?I can look at my diagram for sure.
  5. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    i would get some of these on my rig if i could get them in clear white
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    my friend has clear white ones on his 94 k1500...there pretty neat..i put a set of marker lights on my truck..20 bucks for the kit form pep boys i thnk there blazer lights..there neat at night and make it look more big rigish lol..
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    L.E.D.'s use alot less energy to run and they last longer, but are also more expensive, i would personally run them in line with the parking lights, i have some regular bulbs similar to this on my light rack, and i have them wired into the parking lights with no problems with the power drain at all. Going to switch to the LED's when i install the new light rack. /forums/images/graemlins/thumb.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have a set, they're tied into the left front marker light. I cut the wire recently and I think I'm just going to tie them into the headlight switch if I can figure out which wire is for the parking lights.
  9. tecton
    Dec 1, 2002
    1,553
    WV
    "my friend has clear white ones on his 94 k1500.."
    where from?
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The stock cab lights don't penetrate the inner roof (ceiling?) just the outer skin. The wire runs down inside the A-pillar. It has a female blade connector on the end. I can't remember where the heck it plugs in though /forums/images/graemlins/thinking.gif
  11. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    So, to add clearance lights to my K20, what would be the best way to run the wire through the roof? It seems like it would be a PITA to connect five lights together between the two "roofs".
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh Im going to swap them onto my truck whenever I get around to painting it, Chevyduty sells most of the stuff for the swap, even sells the stock style wiring harness if i remember right. I think the lights tie into the headlight switch behind the dash, atleast thats what I read on here or got in an answer from chevyduty(been awhile since I looked all the info up).
  13. divorced
    Jul 20, 2004
    5,115
    I checked chevyduty and the harness is $44.95. That's a little more than I wanted to spend on wiring, has anyone done their own wiring?
  14. soupman
    soupman Registered Member
    Nov 12, 2013
    37
    nashville
    So, how are most folks doing this.... penetrate both roofs?
  15. Big Ray
    Big Ray 1 ton status Premium Member
    May 17, 2009
    10,555
    681
    Eastern NC
    this is a zombie thread...look at the dates...:whistle:
    as far as your question, I don't think so...
