Cab floor rust repair-cab support
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by elacruze, Oct 1, 2004.
  1. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    I'm replacing the floor pans, rockers, and cab floor supports on my '85 K3500. Problem is, the main cab crossmember on the driver side is rusted through and I don't see a replacement available. Anyone have a better solution than a wire brush and plate steel?
    Eric
  2. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    I am having the same problems on my 78' Blazer, I have purchased all the stock cab supports I could locate and welded up what I could to save the factory supports. I am going to make extra braces to support the cab as I don't rely on the old rusty metal that is left in there. I am using 1x1 square tube stock and it is fitting in nicely. as for the floor pans " there is no way in hell I am paying over $400 for some cheap japanese sheetmetal just because it is preformed. I purchased (4) 4'x8' 16ga sheets of steel and will fit it up myself, I don't care if the floor is higher, but my bank account will be. Good luck!
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Body shop /forums/images/graemlins/whistling.gif
