Cab mounting
Discussion in 'The Garage' started by blazinjimmy, Sep 5, 2006.
  1. blazinjimmy
    blazinjimmy Registered Member
    Aug 28, 2003
    53
    If you could direct me to any info...it would be appreciated. I am curious if a cab mounts directly, with no mods. I have a '74, and an '89 jimmy, and want to put a cab on one.
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    By "cab" I assume you mean pickup cab ... IIRC, they work better on one of the earlier, or later frames, but I forget which... prolly later, as they have more room in the foot area of the Blazer tub.
    In any event you'll hafta fab rear mounts for the pickup cab, but IIRC the front ones will match up.
    -- A
  3. blazinjimmy
    Aug 28, 2003
    53
    sorry....yes pick up cab......was hoping I could mount a cab to one of the frame styles...with no mods./////oh well
  4. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    If you use a later blazer frame you will have to make rear mounts. front mounts will line up. What I did for the rear was use the rear cab crossmember from a pickup and made uprights to mount it to the frame.
    Here it is with just the crossmember bolted to the cab.
    And now the uprights are welded to the frame and crossmember bolted to uprights.
    Here's the link for the build up http://coloradok5.com/forums/showthread.php?t=175060
