cab removal q's
Discussion in 'The Garage' started by jones, Jun 1, 2006.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    just one question,actually.how does the cab come off the frame?the front fenders are ready to pull,the seat is out as well as the carpet.i cannot figure out how to remove the cab.please help!
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    there are bolts thru the frame into the cab. crawl underneath the truck and you'll find 4 bolts.
  3. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    :haha: :haha: :haha: i thought the carpet and seat held it to the frame?
  4. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    carpet
    yup
  5. jones
    May 17, 2004
    379
    IONIA,MI USA
    at least i made someone laugh!i was in a hurry and didn't explain myself.i know that the 4 bolts hold the cab to the frame and where they're located.the nut thats supposed to be welded to the inside of the cab supports is spinning.it's to rusted to re-weld it,so any other ideas would be helpful.thanks guys!
  6. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    cut!..
    Cut the head of the bolt off with a sawsall or torch..or peel the thick washer off thats under the bolt head(if its still there!)..the frame bracket for the cab mount bushings has a hole big enough for the bolt shank to pass thru when the cab is lifted off..
    Here where I live,we rarely have to unbolt a cab..the mounts,rubber bushings,and bolts are usually already rotted off,and all we had to do was lift the cab off!...we have to weld big washers or plates to the frame brackets in order to bolt the cab back on properly...:crazy:
  7. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    you will need to cut through the floors to access the pocket where you will find the square nuts that are spinning
  8. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    yuppers.... I have 1 that did that... then I gam a HUGE flathead screwdriver in there.. have someone pry while I turn the bolt.. worked fine...for me :wink1:
