Cab roof question 1991 GMC - Drilling
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RJB44, Feb 17, 2007.
  1. RJB44
    RJB44 1/2 ton status
    Dec 3, 2005
    238
    Northern Virginia
    I am interested in installing a combination map light and clock unit in the cab of my 1991 GMC Jimmy. I want to put it front center on the inside header area. I have the one piece molded unit with wiring. I want to assume that the sheet metal for the cab roof is two ply, meaning if I drill screw holes from the inside, I won't end up going through a single layer to the outside the of the roof. there are two screws that support this unit. I have puilled back my header material but just want to make sure I am safe to drill in that area. Thanks
    RJB44
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    My 76 cab had 2 layers so i am pretty sure the 91 will too.
    :D
  3. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yep. 2.5 to 3" front & back and about 3/4" in the middle.
    Over the windshield there is some bracing as well.
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I'm not sure but the LMC catalog may have the parts breakdown.:D
