Cab Rust cleanup
Discussion in 'The Body Shop' started by Ulfhedinn, Apr 15, 2011.
  1. Ulfhedinn
    Ulfhedinn Registered Member
    Mar 24, 2011
    39
    A Den in So Cal
    As you can see I have some rust damage. I assume some of this will have to cut out and replaced with new metal. How should I prep the clean up of this. First time doing this...
    Do I need to sand it tell I dont see anymore rust or until its flat or ?
    I have a drill with a bucket wire brush <not sure the name is correct>
    Random orbital sander with some 60Grit currently.
    What else do I need to purchase.
    My plan is POR-15 treatment aka Marineclean then prep & ready followed by Por-15 followed by Al's Liner Heat and Noise Reducer followed by LineX or a do it at home brand.
    {Cant seem to attach pics.. working on it}
  2. Ulfhedinn
    Mar 24, 2011
    39
    A Den in So Cal
    More pics
  3. Ulfhedinn
    Mar 24, 2011
    39
    A Den in So Cal
    last but not least
  4. 4x4orbust
    4x4orbust 1/2 ton status
    Jul 10, 2010
    104
    SE mass
    some of that looks like surface rust, and can be dealt with without cutting it out and replacing it. do you have a grinder? a wire wheel on a grinder does a good number on rust. then treat it with your choice (por 15 it seems).
    my motto usually is if there isn't a hole (from rust) wire wheel/flap disc it, por 15 it, and paint it. if there is a hole, cut it out and replace with good metal. i see you have some bad rust around the door jambs, that will need to be cut out and replaced. rust like that (big flakes of rust coming off) spreads fast in my parts.
  5. Polski-Chevy
    Polski-Chevy 1/2 ton status
    Jul 21, 2008
    523
    At the Edge of Madness: It's actually surprisingly
    ^^This^^
    My late model chevy has more rust than that! :haha:
    Your in real good shape if it's not rusted thru. You don't know how lucky you are to be located outside of the rust belt. I am jealous :whistle:
  6. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,704
    21
    Paducah, KY
    I dunno. Some of those seams look pretty crusty. I'd definitely check and see if you can see the bottom/other side of some of those. These things usually rot from the outside/bottom in/up.
    I'm just saying because I've had bad luck on other vehicles with thinking some crust was just surface and then finding there was nothing but crust left...
  7. Ulfhedinn
    Mar 24, 2011
    39
    A Den in So Cal
    There is a couple of really thin areas on the cab floor. I assume I will have to cut and weld in some new metal in those spots.
