Cab spot welds 91 Jimmy
Discussion in 'The Garage' started by big jimmy 91, Mar 3, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I was sitting in my truck this morning and noticed that the spot welds around the door jamb under the weather stripping look like they are cracking.
    When I pulled back the w.s. it seems to be doing it on both pass.&dr. side along the top and down the w.s.pillar
    Is this a common thing?
    Should I be concerned? /forums/images/graemlins/dunno.gif
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You mean at the back of the door opening, like where the bedside is tacked on? (I am assuming so). That is very common. You can re-tack it but will have to do it repeatedly if you flex the truck. You can just give up on it (I did after 3 tack sessions in 6 months). If you give up it will get worse and start cracking around the half cab. That is why the bedsides get removed on the trail.
