cab trucks?
Discussion in 'The Garage' started by jaysonsk5, Jan 13, 2006.
  1. jaysonsk5
    jaysonsk5 1/2 ton status
    Aug 11, 2005
    229
    eastern iowa
    thinking about doing this to my k5 can anyone give me some tips and picks, or resons why not to do it? thanx:D
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    IIRC, backyardbuilt and Frizzlefry here on CK5 have cabs on Blazer frames with mini beds on the back.
  3. jaysonsk5
    Aug 11, 2005
    229
    eastern iowa
    thanks for the pics, ben.
    i'm wanting to get some more info on the swap
    and how it works from someone that has done it:D
  4. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I talked to frizz breifly at blazer fest this past year. He said he drove his balzer into his shop one day and out the next day with a cab on it. Sounds easy.
    Im planning on dropping a 70 cab on my 79 blazer frame. I figure ill have to make some new body mounts but other then that dont see too many challanges.
  5. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    You need a cross-member for the rear cab mounts as the blazer doesnt have one. The cross member needs to be placed ontop frame due to a dip or something in the fram that cab trucks dont have. Ive been looking into doing this for a while and probly will in the spring. the cab is straoght foward from what ive learned except for those rear body mounts. THe bed is the more diffucult part from what i understand. I belive its easier to cut down a Stepside bed.
  6. jaysonsk5
    Aug 11, 2005
    229
    eastern iowa
    dose anyone else have any info of more pics of this swap?
  7. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    You may want to PM B_TO_C I know he has done the swap. From what I hear its very easy.
  8. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I've done the swap. I also talked to frizzlefry before I got underway just to see if he had any suggestions. It's true...he was drivable in one day, but I have to stress that his is a carbed truck. Once you get wires mixed up in everything it adds a little time. My truck was drivable in three days though, still not a big deal. (originally a 1990 blazer, with a 1985 cucv cab). But even the wiring is simple as long as you label everything.
    Here is a shot of how we (me and Mrk5 did the swap...his shop) did the rear cross member. We found it was actually quite simple. We welded the original truck crossmember to a 2x4 piece of tubing that spanned the frame railes, then used another chunk underneath each side sitting ontop of the blazer body mounts. So essentially...we were connecting the trucks body mounts to the blazer body mount points, just in a roundabout fashion. -There is a bolt that goes through the 2 sections of 2x4 tubing and through the original blazer body mount hole.
    Eventually ended up with this...
    More pics in Mrk5's gallery here: http://photobucket.com/albums/y177/MrK5/Project%20Flatbed/
    Any other questions just PM me.
