CAD help
Discussion in 'The Lounge' started by MNorby, Apr 11, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I am trying to blueprint some stuff for work and keep having probs. Its been 4 or 5 years since I have messed with cad and it really shows. I have autocad 2006 and i learned on '02 if there is much change. Trying to draw a circle with a diameter of 74.5" and it keeps going soo big when I zoom all the way out it still takes up the whole screen. Are my dimentions set wrong or do i need to setup the page somehow.... I can't remember.
  2. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    I'm not great with autocad .. but as I remember all drawings were scaled. so for a 74.5" circle on screen you would wanna do like 7.45"
    I might be wrong though.
  3. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    you mean 74.5 right? I though I just hit circle, hit D for diameter and that works, I type in 74.5 and hit enter and it draws a circle but its huge and it's like I can't zoom out far enough to see it all.
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    zoom all is your friend ;)
  5. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    can I just enter the number for inches to draw it to scale?
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'm afraid I have to know exactly what you're doing in order to precisely answer that question.
    What size sheet are you printing it onto?
    What exactly are you trying to accomplish with the drawing?
    Know how to calculate a scale factor?
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Sounds like your paper space is too small. In the initial drawing set up your paper space should be set just larger than your planned drawing in the same unit of measure.
  8. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    basically I am drawing a huge propane tank saddle mount that I am going to build.I open CAD
    click to draw a circle
    type D for diameter
    type in 74.5 for the inches the tank is in diameter
  9. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    how do i set my drawing space larger and how can I tell it i am drawing in inches?
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Alright, I don't have the program on this comp (kind of a memory thing for me) but IIRC type "limits" into the command line, and just set numbers larger than your overall drawing will end up being.
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    It draws based on units. That's were scale factor comes into play. If you don't need to print it then it doesn't matter, if you do, then a little tweaking is required once you finish and get to layout. Kert undoubtedly uses this stuff every day so he probably remembers far better.
  12. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    like limits for height and width?
  13. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    yeah, idea is to draw it then dimention it then scale down and plot
  14. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    yep, if your drawing is going to be 74x74, when it asks, just type in like 100,100 or something like that
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Tell ya what, set up the limits, draw, dimension, and then I'll do my best to guide you through the scaling and plotting. Like I said, I don't have it on this comp and it's sort of an automatic thing so I don't remember the exact commands.
  16. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I think once I get it setup I can remember most. Took a class on it in 2002. I'll get started and get back on here...
  17. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    trying to draw something like this... Tank is X" radius and the stand (green) is 4' tall and 10' wide. I wanna dim out the curve I have to cut out of the 4x10 plate to fit the curve of the tank plus the 3/8" thick strap I will lay down that the tank will acually sit on in that curve
    I think I got my radius wrong because I can't remember the circumfrence of the tank off hand. Will have to get that from shop but I rmember it is around 10' diameter so could go off that so I cna figure out.
  18. CustomChevy
    Jun 29, 2005
    4,328
    this conversation would be 100% easier on irc!
  19. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    ...or msn or yahoo.....
    but this is one serious pad posing too......
  20. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    can i attach a cad drawing file....
    nope.
    Anyone wanna look at this and see what they think?
