Caddy 3R gripes
Discussion in 'The Garage' started by rcamacho, Mar 12, 2007.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I have a 3R type shaft that I've run for a few months. The centering joint went out due to contamination. Anyone out there ever have success modifying the CV to lube the center?
    If not, it seems like I'll dump the shaft and go with a 1350 shaft from High Angle Driveline. It will run me $275 to have the 3R repaired and shortened a bit compared with $400 for a new 1350 shaft from HAD.
    http://krazyk5.com/phpBB2/viewtopic.php?t=2066&highlight=
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The stock one in my '90, the spare one I bought, and the one in my buddy's older truck all have greasable centering balls. It's not a standard zerk though, but one that requires a needle attachment, and it's pretty hard to see if you have any gunk or grease on the shaft.......
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks. I've disassembled the 3R CV a few times and have not found a zerk on it even one of the flush needle type.
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i know u hate to spend the 400 bucks, but i swapped to one of jesse's 1350 cv shafts & it is the shat. no more vibes & trouble free service. it is quality stuff
  5. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Just make sure that they are putting in a grease jerk for the ball/cv. The first HAD 1350 cv slip yoke I had didn't have one in it and the exact same thing happened to it...then I had to have the cv rebuilt...which wasn't cheap by the way....
  6. rcamacho
    Jul 1, 2004
    1,324
    WA
    Will do... :)
