caddy 500 to a 700r4
Discussion in 'The Garage' started by shaun, Sep 13, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Is this possible. Is there an adapter. I just got my self a 500 and I want to run my 700/241. Is this going to be possible?
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Yeah sapters are fairly cheap. but i dont think the beefiest 700r4 will last behind a caddy 500, even stock.
  3. shaun
    Apr 22, 2003
    745
    I was going to run a raptor 700 or a bowtie overdrive. They say it will hold. Where can I get these adapters?
  4. ben427
    Mar 10, 2002
    1,123
    I had one from canadian high performance discount, but i'd imagin Jegs, or summit would have them.
  5. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    it would be the same as a bop-chevy adapter.
  6. ben427
    Mar 10, 2002
    1,123
    that would be the one, the one i had was made by Hughes.
  7. shaun
    Apr 22, 2003
    745
    I will try and find one. Thanks
  8. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    500cid.com, call them, thats where i bought mine /forums/images/graemlins/waytogo.gif
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    A professionally built up th700 will do just fine behind a stock or mild caddy 500. /forums/images/graemlins/thumb.gif
  10. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Why not run a 700R4 from a pontiac,buick,or oldsmobile--they already have the same bolt pattern as the Caddy--I think they might have some with the "Unibell"bellhousing with both GM bolt patterns in it also.If not,the adapters are about 60 bucks from Jegs or Summit.I think a good 700R4 will last behind a 500,if you dont whale too hard on it,and run a good cooler,its no TH400,but it should be ok for light to medium duty use--just dont do brakestands or tow heavy trailers and it should live--. /forums/images/graemlins/crazy.gif
  11. shaun
    Apr 22, 2003
    745
    Thanks guys. I ordered one from jegs. 55 dollars. No biggie
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    IIRC, the 200R4 was the BOP tranny. I don't think a th700 was ever used behind the BOP motors, could be wrong though.
    I stress again...a built up 700 will last just fine, brake stand, pull heavy loads, what ever. I pull some heavy trailers behind my K5 with a built 406 in front and relatively tall 4.10's/35's.
  13. dyeager535
    26,982
    191
    No such thing as a BOP 700R4 unfortunately. 2004R was the unicase (and/or BOP only) OD tranny, and can't be used for a 4wd swap. (easily anyways)
  14. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    What about the flex plate to torque converter? what kind of spacers would you use for that?
  15. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    for a street rig this might work... but I'd be worried about toasting 700s with regularity if you really use the rig hard. 500 caddy is a whole lotta motor. Toss a TH400 in there and be done with it.
    j
  16. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    There is a reason these motors came backed by TH400's in the Factory. For the sake of peace of mind (unless you really baby your rig), I would strongly recommend a TH400, or 4L80e.
  17. dyeager535
    26,982
    191
    No pro on this, but I believe the torque converter bolt patterns are prtty much all the same. Some "dual pattern" flexplates, but I believe that was on the TH400 flexplates.
