Caddy big block guys. UPDATE PICS
Discussion in 'The Garage' started by cybrfire, Oct 3, 2004.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    How far is it on your setup from the middle of the hole in the block to the top of the frame rail? Just looking for a close estimate.
    UPDATE PICS
    [image]Front_mount_layout[/image]
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Re: Caddy big block guys. Have a question for you?
    TTT for the caddy guys to see.
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    sorry, saw it, but have no input /forums/images/graemlins/whistling.gif /forums/images/graemlins/thumb.gif
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I think boz42 has a caddy in his doesn't he?
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    dhsender/dhcender or something
    uncle matty
    and seventyfive or something from fallen nv, all have caddy motors
  6. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    sorry man, I got mine pulled out for boring and stroking
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I can prolly get a measurement for ya tomorrow after work off of ksblaze83's K5. he has a 472 will that work?
  8. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i do not know off hand, my blazer is at my buddies shop. we set it low in the frame. i would guess it is about 2" above.
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That will work. Thanks a bunch.
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The top of the frame rail is 2" above the bolt hole you think? I was figuring about an inch would be fairly close.
  11. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Mine is still in the garage in process. Sorry cant be of much help.
  12. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    sorry i was wrong on my guess the top of the top hole were the motor mount bolts in is dead level w/ the top of the frame. headers were a tight fit had to modify them to clear the d-shaft on the d-side, cause it hung so low.
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Thanks boz42. Heard the exact same from another guy so that helps a bunch. I should be able to post pics of my mounts hopefully by the end of the weekend. Will be pretty close to complete.
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    UPdate at the top.
  15. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    the engine plate is a good idea, in case u missed it in one of my posts this is a pic of how i did it.
    it is the only pic i have /forums/images/graemlins/weld.gif
  16. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That's pretty clean. Is yours solid mounted? Hard to see from the pics if there is bushings in there.
  17. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    it has bushings. i bought spring eye bushing assemblies from ORD that had 1.75" dom for the outside tube. they were too wide to fit between the caddy engine mount plates so i took them & narrowed up the bushing assembly a bit so they would fit. the rest of the tubing is 120 wall 2" dom. i am happy w/ how it turned out. /forums/images/graemlins/grind.gif
  18. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That's pretty slick. I like how you used the tubing to wrap around the pan.
  19. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    thanks, here is the same pic unedited
  20. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Looks like you had to notch the frame. Clearance for the drag link?
