caddy caliper parts???
Discussion in 'The Garage' started by RootBreaker, Mar 10, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    Ok so it is my fault... I have had the parts to do the rear disc conversion for MONTHS now... I bought 1976 eldorado calipers from car-part.com for $45 to my door... anyhow.. they warrantied them for 90 days (basically guaranteeing they work or money back).... So I was having a problem getting one to move a while ago... so I used my air compressor and blew into the bleeder hole... MAKE SURE YOU HAVE 1 PAD IN SO WHEN IT SHOOTS OUT AND SOUNDS LIKE A SHOTGUN YOU DONT LOOSE THE PARTS!!!!
    anyhow... inside I replaced a few seals.. but noticed that there is a washer to which mine was in 8 pieces and another washer with 3 bearings in them... then another washer... well I need to know where to get those as the washer and the bearing piece are no good....
    or is it just better to use this as a core and try and find a new one??????
    any info greatly appreciated.. or I may just put d44 calipers on but I dont have a core... thus cheaper to go with caddy ones.....
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am just asking but why did you want the piston to move?? you arnt supposed to move them at all :)
    I learned the hard way and it sounds like you did also.
  3. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i used my car-part ones as cores. well worth the money to get new ones.
  4. RootBreaker
    Nov 29, 2001
    5,118
    173
    when I got them.. one was all rusty.... the piston itself.. so I too it apart... I took both apart... go the good one back to gether to use to see how it went back together...
    I think what I am going to do is just buy the d44 ones for now. I dont need an ebrake as I already passed inspection. I have 2 years until my next inspection...
    so autozone has d44 calipers for like $15.99 plus $10 core...so I will do that...
    $60 and I will be up and running as I will get the caddys later...
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    aight... gonna just pickup d44 calipers tonight on my way home.... wife is going out so gonna pickup some beer and tear her apart...
    will let yall know how it goes later...
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Those broken "washers" are actually bearing races. They're very hard, but as you found, they're also quite brittle. I have bought replacements in the past at a shop that just sells bearings. They measured the pieces and handed me new ones for around $1 each. :)
  7. RootBreaker
    Nov 29, 2001
    5,118
    173
    I havent driven the truck yet to checkout the brakes... Some people say you dont need an adjustable portion valve and some say you do... we will see....
    Ok so here is Old Shool...
    Sorry was dark so I did not take any pics..... but here is the end result...
    Left
    Right
    Cant tell too well but nice and shiny...
  8. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    so how they working for ya??
  9. RootBreaker
    Nov 29, 2001
    5,118
    173
    dunno first line said I havent driven it yet...
    gonna go outside and adjust my carb first... then finish snorkel and then take it out to test brakes.. maybe going wheeling tomorrow...
    :cool1:
  10. RootBreaker
    Nov 29, 2001
    5,118
    173
    took the truck out for a bit... brakes are not as responsive.. maybe air in the lines still... dunno...
    but the good thing is when i was going down a road a few weeks ago.. had to hit my brakes hard and the back end slid out from me as they locked up... now i can hit the brakes and seems to slow down faster and the back dont lock.. need to wear all the parts in then stomp on them... dont want to hit them too much hard now until they wear in....
  11. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Ever consider a pinion brake? Less functioning thing to go wrong because the parking brake is seperate from the functional brakes and you ditch 2 cables hanging down.
  12. RootBreaker
    Nov 29, 2001
    5,118
    173
    yeah I think in 2 years I will do that when I am up for inspection... if they fail it I will have to go the caddy way :frown1:
  13. fliptuner
    fliptuner Registered Member
    Apr 20, 2004
    16
    B.C., Canada
    Here's a silly question: why'd you only run flexible lines on the one side?
    Also, just for future reference, if you're gonna be running the Caddy's, you'll want to mount the left on the right and VV, unless you want the ebrake lever to hang low.
    http://www.off-road.com/chevy/reviews/tsm/
    Luckily (or maybe not) I haven't run into that problem yet. SINCE I CAN'T FIND THEM BLOODY LEVERS AND SPRINGS!!!! :mad: :mad: :mad: :(
  14. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    He does have flex lines on both sides. The way his hard lines are routed is a little odd though, and combined with the camera angle it appears there is no flex line on the left side (although it is there...)
    Rene
  15. fliptuner
    Apr 20, 2004
    16
    B.C., Canada
    Ahhhh. I see it now. Didn't notice it loops around.
    i ar teh smrt :frown1:
    We should chat soon, Rene, but I'm too ashamed of my truck to call. :blush: :doah:
  16. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Just call me Andrew. The state of your truck has nothing to do with whether or not you should call me. Maybe I can help...I don't work nights anymore.
    plus I lost yer damn number again...:blush:
    I'm home by 5:30 every night.
    Rene
  17. RootBreaker
    Nov 29, 2001
    5,118
    173
    hmmm I was told to always put calipers on with bleeder up... seems that this guy put them on upside down... guess that would work but if I do that... I will be pulling on the ebrake and only getting 1/2 pull on the lever... currently yeah my levers are down so the ebrake is low but pulls on the axle and pulls the ebrake all the way....
  18. RootBreaker
    Nov 29, 2001
    5,118
    173
    how about this adjustable???
    no pic but says fully adjustable and only $15.99
    http://store.summitracing.com/defau...rt=DCC-4452987&autoview=sku&Ntk=KeywordSearch
    found this for a pic somewhere else...
    from
    http://www.mopartsracing.com/parts/dtrain.html
    also reading on this...
    they say that they go on the back to restrict pressure..
    I am not having the back lockup but need to give more pressure to the rear...
    so this isnt going to amplify pressure... should something like this go in the front????
  19. dyeager535
    26,982
    191
    Only way I'm aware of to increase pressure is to change the master cylinder...the front and rear pistons in the master cylinder are "independent" (even thought they are in the same bore) so I don't think restricting one will increase pressure in the other.
    I don't think the fittings are interchangeable, but if they are, put the front on the rear at the master and see what happens. :)
  20. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    root. www.inlinetube.com
    call them and get the proportioning valve. i got one and a bunch of others run them and love them. for 40 bucks more its worth it
    if not, i have a brand new one like the one your looking at if you want it cheaper
