Caddy caliper question
Discussion in 'The Garage' started by GM Man, Apr 15, 2006.
  1. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I did a search and I couldnt find what I was looking for. I picked up a set of calipers off of a 79 caddy fleetwood, will these work or do I need the eldo calipers?
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I believe you are looking for the ever rare 77-78 eldo calipers they have bigger pistons on em.
  3. GM Man
    Jan 12, 2003
    549
    Denver CO
    The piston size on these are about 2 1/2 inches in dia. Do you know the size of the eldo calipers?
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    It's not the piston size that is the issue, its the rotor thickness that matters. The fleetwoods run a bit thinner rotor than the eldo's. The eldo's run the same thickness rotor as ours.
  5. frankin5
    frankin5 Super Mall Crawler Premium Member
    Oct 15, 2002
    883
    114
    chico,calif
    to use this calipers, you have to use the rotors off the 88 and up IF pickups. 1" thickness.
  6. GM Man
    Jan 12, 2003
    549
    Denver CO
    I measured the thickness and compared it to the 10bolt/D44 calipers that I have and the Caddy calipers have about 1/16 more room than the 10bolt calipers do. So I'm wondering if I right ones or not. Does anyone know if they changed the bolt pattern on the calipers??
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The only calipers that will work with an E-brake are 1976-1978 caddy eldo. The fleetwood and deville calipers use a thinner rotor and therefor those calipers won't work. The calipers look the same as far as bolt spacing goes but the pistons are different thickness not allowing them to fit over the 3/4 ton rotors.
