Caddy calipers 14 bolt FF ?'s
Discussion in 'The Garage' started by LUBA, May 19, 2003.
  1. LUBA
    LUBA 1/2 ton status
    Jan 16, 2002
    127
    Bay City, Michigan 48708
    Caddy calipers 14 bolt FF ?\'s
    I got 1976 caddy eldo rear calipers and pads, Derbinator's disc brackets, new 77 chevy 3/4 ton front 4x4 rotors and I am trying to do a rear disc 14 bolt FF swap. The problem is I can't get the piston all the way flush with the caliper body, and the brake pad will not fit. Is the caddy caliper piston supposed to be flush with the caliper body? I took the bleeder screw and the banjo bolt completely off and put in a press, but piston won't go flush. Those rotors are to thick? Also does anyone know the spring pad distance for a 97 yukon gt? That is what I will be putting this 14 FF in. It looks like I have to move the perchs out and maybe the shock mounts. Anyone know the tricks involved?
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Re: Caddy calipers 14 bolt FF ?\'s
    Undo the bolt on the e-brake lever, remove the lever and you adjust that nut to bring the caliper pad flush with the caliper. Have fun.
  3. stu
    stu Registered Member
    May 2, 2003
    59
    Bucks County, PA
    The calipers of that generation caddy are a screw type caliper. Also the piston will not sit flush because the (stock) brakes clip onto the piston. I am in the process of getting the parts for my 12 rear. Any idea where I can get the brackets for this. I have everything else.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    arent the ford rotors thinner???
    nathan
  5. LUBA
    LUBA 1/2 ton status
    Jan 16, 2002
    127
    The directions I got off here using the brackets I got (Derbinator's) say to use chevy 77 3/4 ton front rotors (4x4). I just can get them to fit.
