caddy calipers with e-brake cables.
Discussion in 'The Garage' started by hack500, Apr 30, 2006.
  1. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    loooks nice, but i hope you dont do rocks, those won't last long
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    even mud can be bad....
    I just noticed one of my brake lines was bent up and leakin now... so gotta get them lines ALOT closer to the axle tubes....:doah:
  4. hack500
    Sep 16, 2005
    523
    Templeton, Ma
    it's usually whatever I find - be it rocks or mud or sand or just dirt. I'm not really extreme about any of it. 'spose I should do sumthin' with them lines. :thinking:
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Ok, this post made me go take a couple pics of my E-brake all hooked up finally. Any questions just ask.
  6. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    How well do they work? I had a set on my truck and replaced them with a high angle e-brake kit because they didn't hold and one started to leak around the arm bolt. I have another truck I want to disk out back, but since it is a manual I have left it alone to keep a parking brake.
    -Alex
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If i set the brake it will hold the truck, now if i start the truck and put it in gear it also will hold, but if i give the throttle a blirp it will roll forward slightly then stop. I have not taken any time to adjust it up any tighter so maybe if i did it would hold even better. I will get around to that after i get my tranny issues fixed.
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    where did you get the things that you cant buy at the parts store? i think they are the levers or somehting?
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I pulled them from the wrecking yard off of a seville/fleetwood caddy. IIRC you have to get one side from a seville and the other from a fleetwood, this is because they mount the calipers one on front and one behind the axle.
