Caddy spy shot UPDATE 10/24/04
Discussion in 'The Garage' started by cybrfire, Oct 20, 2004.
  1. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Might shift it back about another half inch but up down ways she's good to go.
    Edit: I did shift it back but more like a whole inch. Snorkle tubes and some other details up front yet.
  2. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    Re: Caddy spy shot
    Nice. /forums/images/graemlins/waytogo.gif
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Re: Caddy spy shot
    /forums/images/graemlins/woot.gif
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Re: Caddy spy shot
    beautiful, when do you think you'll get to drive it?
  5. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Re: Caddy spy shot
    Father's day!
  6. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    Re: Caddy spy shot
    huge by large! /forums/images/graemlins/peace.gif
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Re: Caddy spy shot
    aw come on, you cant be serious! /forums/images/graemlins/thinking.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/screwy.gif
  8. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Re: Caddy spy shot
    That's the target date. I have lots to do yet. Should make it though. Don't know about the other two that are aiming for that date though. Maybe they will chime in.
  9. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Re: Caddy spy shot
    8 months from now, dang, you must have a lot to do! /forums/images/graemlins/thumb.gif
  10. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Re: Caddy spy shot
    Finish mounting engine
    Rebuild engine
    cage
    seats
    shocks
    trans
    xfer
    drive shafts(got a freebie coming from HAD)
    most of the electrical
    spare tire mount
    air tank for OBA
    OBW
    Armor
    winch
    brake lines
    fuel lines
    radiator and elec fans and plumbing it from one end to the other.
    then the whole slew of little things that ties it all together.
    Maybe not that much but that list sure looks shorter than I think it should
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Re: Caddy spy shot
    woah! Thats quite the list!
    Caddy looks awesome!
  12. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    Re: Caddy spy shot
    that looks familiar, put a bfh against the firewall & push it on back
    lookin good, i am aiming for christmas
  13. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    Re: Caddy spy shot
    mine was almost against the firewall, & w/ the doubler i wound up w/ equal length d-shafts, which i thought was cool. only need one trail spare.
  14. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Re: Caddy spy shot
    Mine is almost contactin the fire wall on the driverside corner. Did yours fit tight there. I already trimmed a corner of the bracketry that holds the brake booster and such to the fire wall. The lip that sticks out on the fire wall has been hammered back but there's plenty of room there yet. Just close by the head in that one corner. Otherwise I could shove it back at least 1.5" yet.
  15. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Re: Caddy spy shot
    Looks very nice.. hopefully next year I'll start mine.
  16. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Re: Caddy spy shot
    Whats up with the nippco /forums/images/graemlins/confused.gif you're not cold are ya /forums/images/graemlins/whistling.gif
    Father's day!
    [/ QUOTE ] He didn't say what year/forums/images/graemlins/deal.gif
    My to do list
    finish cutting fenders
    remove rocker and install sq. tube slider ( one side is done)
    then take the body off again
    remove and rebuild the 205/203 grear box
    remove and rebuild the th350 add reverse manual v/b
    remove the engine and check the main and rod bearings
    clean and paint and install the 4 above items
    build trans tcase cross members and flat belly pan
    HAD drive shaft x 2 1410 yokes
    install DEtroit in the 14b
    make custom stainless radiator tubing/hoses
    wire the engine
    exhaust
    anti-rap bar
    turn the 57's around to help departure angle
    shocks
    cage
    seats
    bumpers front and rear
    flat bed
    bump stops
    OBA
    spair tire mount
    electric fan
    winch??? maybe
    hydro-assist
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  17. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Re: Caddy spy shot
    Anytime you want an extra hand stomper gimme a call /forums/images/graemlins/waytogo.gif if i dont have class ill come help out in whatever way I can, still learning alot but i could help with the prep and paint work.
  18. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Re: Caddy spy shot
    Father's day!
    Nope, not cold but if it wasn't under the truck it'd be totally buried in one of the other various storage locations. Just thinking ahead.
    Definitely, if you get some stuff lined up to do I could buzz over there some weekend to do some wrenching as well. Make it a wrenching party. You buy the beer! Hell will just crank it up and keep going until the beer is gone or we pass out.
  19. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Re: Caddy spy shot
    You two have me beat. Time for the SPRINT to the finish. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/hack.gif
  20. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Re: Caddy spy shot
    UPDATE at the top...
