caddy swap semi write up w/ pics
Discussion in 'The Garage' started by boz42, Oct 12, 2004.
  1. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i recently swapped a cad 500 into my k5. i pulled it out last night so i could take it to the machine shop to get that ball rolling. i used the dissasembled engine for mock up.
    the first thing i did was completely remove the engine crossmember. u can retain it w/ some trimming, but i never intended on keeping it so i pulled it out. next i boxed the frame from the frt bumper horns to behind the frt spring's rear shackle (i know this has been a topic of heated debate here lately, but that is the way i decided to do it good or bad & this is also not what this post is about). next i put the 500 & the t-400 in the k5 suspended from a cherry picker in the frt & the tranny crossmember in the rear. did a lot of measuring & decided on the best all around locale for the eng. we did try to get it as low in the frame as we could w/ out fear of getting into the frt axle & steering components. the new engine mounts & crossmember are made from 2" .120 wall D.O.M. except for where the bushing is & that is the same material but 1.75". one side of crossmember is missing a kicker brace. i used 2 stock t-case crossmembers i modified the frt one to clear the frt d-shafts i also had to make some 1" spacers for the 203 adapter to sit on. i modified bbc headers & had to shorten the pass side one to clear my front d-shaft. my 500 is from a 75 eldo so i had the good oil pan everyone wants. i used a bop t-400. i used dyno max headers w/ header flanges from M.T.S. i used 2 spring eye bushing assembly from O.R.D. to make the engine mounts. the pics are small & low quality do to me being on dial-up still. here are the pics:
    2 doubler crossmember pics:
    4 engine crossmember pics:
    header pics
    doubler installed
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Looks good. I'll have to get mine in this week and post up some pics as well. Nice work.
  3. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    thanks i put a lot of time into it.
  4. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    That looks pretty nice. A little more involved than what i plan on though. I think i'll do mine like this
    Probly not as strong or as properly done as yourse but i think they ought to work for me.
