Caddy trans questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K1Orion, Feb 14, 2004.
  1. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    My buddy scored a 500 Caddy with a 350/203 for $100 today. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif Problem is the 350 has got a hole in the case under the govenor cover so he needs a new trans. He plans to use a 350 again since it will be the easiest to locate and build.
    SO, Does a Caddy use the BOP bellhousing pattern? What should he be looking for in a new core? Can he use a complete 2wd or will he need to swap in a 4x4 output shaft?
    Was there ever a K case trans with a BOP pattern?
    Thanx
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the few 500 caddies ive seen were chevy bellhousings.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    TJ, the few Caddy's you've seen had Chevy engines in them then. and they werent 500s either. Caddy uses the BOP bellhousing.
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    no actually there were to "caddy 500" in a sand dragster. i said that they were 454s but the "owner" said that they were cadies /forums/images/graemlins/dunno.gif
  5. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    Find a BOP T350 Tranny and have a shop swap the 4wd trans guts (output shaft mainly) into it and make the case a short shaft case. That is what is done with mine and it works great. A good tranny shop will do it for you no problem and if they say it can't be done move onto a different shop.
    As for the Chevy trans behind a Caddy motor yes it can be done with an adapter so its possible that is what he had just left out the adapter portion of his swap.
  6. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    there is no bop k-case.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    there is no what? /forums/images/graemlins/confused.gif
  8. dyeager535
    26,976
    K-case is the thicker transmission case used on K(4wd) trucks.
  9. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    Thanx for the replies everybody! /forums/images/graemlins/thumb.gif
    Turns out my friend didn't buy a 500, its a 425. But $100 for a running motor with all accesories, junk trans and a 203 is still a pretty good deal. I relayed him all the info I got here and also pointed him to www.500cid.com which I found in the other caddy post. Its just too bad he's gonna put the setup in an 80 CJ-7. /forums/images/graemlins/doah.gif
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    k case started in 78, otherwise all earlier 4x4 trannies were non k case
    you can swap 4x4 tailshaft into any th350 regardless of make it is/bellhousing pattern it has, so you can make a BOP 4x4 tranny in which never existed in factory produced form
