Cadillac caliper e-brake or np241e-brake?
Discussion in 'The Garage' started by ruth95, Apr 7, 2004.
  1. ruth95
    ruth95 Newbie
    Apr 30, 2003
    Washington state
    I'm converting a 14 bolt ff axle to disc brakes and don't know if I should shell out the money for the Caddy calipers or try and find an e-brake set-up for an np241 transfer case if one exists? any help would be greatly appreciated! <font color="blue"> </font> /forums/images/graemlins/dunno.gif
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Try Jesse at High angle drivelines for the 241 e brake kit.I've got driveshafts from him, top quality stuff. I will also get the 205 e-brake kit soon.
  3. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    I have the High Angle on my 241 with the JB Conversions SYE.
    I love it, but as you can see, I had a little floor pan mod to make to get it in with no body lift, and not dropping the xfer case...
    Here's the cover I made to cover the disc on the inside of the truck.
  4. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    What did that np241 ebrake settup cost?
  5. ruth95
    ruth95 Newbie
    Apr 30, 2003
    Washington state
    Thanks for the help, maybe there is hope! /forums/images/graemlins/peace.gif
  6. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I went with the AZ-Kickin brackets and the TSM Caddy calipers. I am impressed with the quality of both of them. When AZ-Kickin gets their full kit together that will include everything needed for a Caddy caliper setup, that will be a nice way to go. I plan on getting their e-brake cables when they make them available. TSM also makes the cables set up for the Caddy calipers too I think.
    [​IMG] [​IMG]
  7. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Was the JB SYE and HID kit a bolt on, or did you have to do some fabbing to get it to work together?
    How much interference is there with the floorpan? Will a 1" bodylift fix the problem?
  8. SCJimmy
    Mar 7, 2003
    406
    The JB SYE was basically a bolt in application. I rebuilt the transfer case at the same time, so I put a little more effort into it, but it's not too bad.
    The SYE and Ebrake were bolt on mods. I used a /forums/images/graemlins/hack.gif to make the slot for the rotor, them fabbed the cover, and installed it on the inside of the truck. The rotor only sticks thru about 3/4", and since I didn't want to do a body lift, this was the best thing I could think of at the time. One inch might do it, but you may want more room to allow for drivetrain/body movement when flexing the truck out offroad.
    The ebrake works really well, and I am happy with the mods, the SYE and especially my 1 ton HAD CV shaft. /forums/images/graemlins/waytogo.gif
    The only thing I would have done differently was to clock the 241 up before I ordered my HAD shafts. Still going to do it if $$$ allows.
