Cadillac HEI fit our trucks?
Discussion in 'The Garage' started by dremu, Feb 9, 2007.
  1. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    Have a chance to scavenge anything I want from a Caddy... it's a '79, dunno what model, so it looks like it prolly has the 4.7L V8. If it had the 500 I'd be all over like Marv Springer over 32-spline '208's.
    Anyway, I can't think why I'd want a 2WD BOP TH400, but if the HEI distributor would fit a Chevy block I might snag it.
    Anybody know how similar the dizzies are?
    -- A
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Don't know much about that year or size cadillac. The old ones share the same cap and rotor and such with our chevys but the stem is specific to cadillac.
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    X2 Cap and some internals, but that's it.
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    As long as we're discussing Caddy dizzy's [hijack] Does anyone know if you can frankenstein a Caddy and TBI chevy distributor to come up with an electronic advance dizzy that will fit the Caddy?
  5. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    tranny might be desireable..
    The Caddy TH400 can be converted to a 4x4 one by installing a 4x4 output shaft..might be handy if you ever decide to go with a Caddy engine..or with an adapter plate it could be used behind a Chevy motor..
    Not sure about the HEI--the Caddy one wont fit a Chevy,other than the internals..not sure if you could morph a Chevy TBI one and a Caddy together,could be done I suppose,whether it would work right would be a guess...:crazy:
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Probably, but it'll take some thinking. Plus some cutting & welding no doubt. I put an HEI pick-up & reluctor in a points dizzy. Not too hard once I figured out what had to happen.
  7. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    why??..
    If you need an HEI for a Caddy you plan to use fuel injection on,maybe a Caddy one from a 368 or 425 V8 would "work"...they did have EFI on late 70's and early 80's Caddys,but I'm not sure what kind,some had multi-port I think,others had TBI..
    As for "weird" distributor conversions,I once "downgraded" a LUCAS distributor on a Triumph Spitfire, by removing the troublesome and costly pick up coil and "ignitior" that failed 3 times in 6 months on my friends sisters car,and simply screwed in a set of Delco-Remy points for a GM six cylinder in there instead,and added a GM coil!(had to drill a hole or two,no major modifications!)..:D
    ..took me awile to get the dwell and timing set,but it ran better than it did with the crappy LUCAS ignition ,and never acted up as long as she owned the car!...(I bet some eyebrows were raised at the next shop that attempted to "tune it up" after she sold it!):haha: ....
