Cadillac Northstar 32Valve V8?
Discussion in 'The Garage' started by Ryan B., May 7, 2005.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I was at the junkyard today, found an all aluminum caddy northstar v8 32 valve dual overhead cam out of a '96 cadillac. Complete with the transaxle, the only thing that was bad looked to be a cracked valve cover.
    So whats the going rate for these engines? Are they in high demand? I know sand rail guys love these engines because these v8's are lightweight all aluminum, and Advance Adapters makes an adapter to couple this motor to a GM tranny...
    So should i go back tommorow and grab this thing for a few hundred bucks? Would make a bitchin sand rail, or i think i could make some good money off it, just selling it? Not sure if it runs but so long as it turns over freely it should still probably be worth some good money? Anyone looking for one of these engines? I'll go pull it and strap it on a pallet? :grin:
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Get it, put it in your dad's jeep. They can make some crazy HP off a stock bottom end too.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    but with the DOHC and smaller displacement(4.6L) they are more top end then bottom.
    You don't really need an adapter for the trans. All you need is a 60* V6 transmission(700R4) and modify the one bolt hole location on the transmission.
  4. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    some years had bad head bolt threads in the blocks and were under recall. and if the starter goes bad its not a trail fix cause its under the intake.
  5. zcarczar
    Feb 10, 2002
    2,495
    There was never a recall for the head bolts, it only affects about a 1/4 of the northstars, if that. and the starter is very easy to do, the intake comes off very easy, even in its stock form.
  6. cybrfire
    Dec 15, 2002
    15,142
    571
    Iowa
    Anybody have an estimaed weight on these? Is the bellhousing still the old BOP pattern? Looking for a light weight engine for a special project. I'd grab it if I were you.
  7. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    If, and thats a big IF, I remember correctly, they are about 550#s complete
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Someone like GM High Performance magzine did a write up a few years ago. It is ALMOST the same bolt pattern as the 60* V6 Chevy motors. One bolt hole needs to be removed and TIG welded to a new spot on the bellhousing. I'm searching for the article.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Here is a specs page
    413 LBS. complete they say
  10. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    heard bad things about northstars...
    I've heard from more than a few disgruntled owners of northstar V8's,--they seem to use lots of oil,and rear main seal and other leaks seem to be common dilemas..but a lot of the bad raps come from how difficult the problems are to fix in the vehicle rather than the motor itself from what I've heard..its not a BAD motor,its the way its stuffed into the caddy's that make the repairs so time consuming and costly...I know a guy with one in an old ford coupe,its a cool looking motor,and it has very respectable power too..not sure how he hooked the tranny to it,or even which one he used,probably the 700R4 like Sled Dog mentioned.... :crazy:
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I would bet you could get a bellhousing from a 60* V6 and run like a T56 behind it.
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I got a friend with one in a 96 caddy seville sts. That son of a gun will flyyyyyy. He had a massive oil leak and hadta pull the motor to fix it, I dont recall which seal it was. Also, the caddies have a problem with water consumption. You have to put in stop leak to keep the aluminum from soakin up water. Thats in the factory manual for the car, weird.
  13. cybrfire
    Dec 15, 2002
    15,142
    571
    Iowa
    Very interesting. Especially the short star v6 but this has kinda turned into a hijack.
  14. zcarczar
    Feb 10, 2002
    2,495
    Its a damn good engine, but holy **** do they leak. Hell we have new ones that leak too. Ive seen some of them that blow head gaskets and blow compression into the crank case so it looks like its got a bad rear main and oil pan gasket. They may leak and blow head gaskets but its rare to see one in for a bottom end problem. The only problem size wise with them is that they are very wide due to the Overhead cams, but the block is pretty small. And Motor mounts are going to be a challenge along with exhaust since just recently they began putting the northstar in rwd apps and thus everything is pointing the wrong way. Good engine though, I thought of putting one in my blazer for a few days but realized that I couldnt get a 4l80 to bolt up and would probably lack the low end grunt i need.
