Cage, bender ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, Jun 24, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Cage, bender ?\'s
    1)What do you use for a roll cage tubing or pipe?
    2)What is the difference between the two?
    3)What size of "pipe or tubing"to use?
    4)What is a nice, reasonably price bender, web link please
    /forums/images/icons/cool.gif
  2. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    Re: Cage, bender ?\'s
    you use tube to make a roll cage
    pipe is mesured form the I.D. inside
    tube form the O.D. out side
    when I buy me a bender I am going to use 2" tube, some people use 1-3/4 " or 1-5/8" to make a cage
    the bender I am going to buy is a JD2 Model 3 it is about 500 for the bender and one die set
    JD2 Model 3
    I am no expert but I thank ever thing I said is right
  3. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I am using the JD2 bender also. It works very well. Plan on using some sort of hydraulic set-up if you want to bend heavy wall tubing. I am bending 2" .134 DOM and you can't do it with the hand lever. I used the ram from my engine hoist in a simple custom set-up. It is a lot of arm pumping but pretty easy, and the bends are perfection. /forums/images/icons/wink.gif Good luck. JT
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    That just about covers all of it. The JD2 bender is a good one. I have a 2" and an 1 1/2" die for mine. Here's a few more things:
    Most people use HREW for bumpers and rocksliders, and some use it for cages. DOM is also used for cages and general fab stuff. I won't get into the strength issues, but they are both OK to use, DOM is usually more per foot.
    .120 wall is a common tube thickness to use for most tube work.
    If you buy a JD2 bender, get the 180 degree dies. Most of the bends will usually be 90 or less, but it's nice to be able to make "hoops" or anything else that would require a bend more than 90 degrees.
    Also, get a decent notcher. Chop saws work, but the notchers will pay for themselves quickly.
    BIGJ
  5. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I have a VanSant model 3 www.vansant.com its the same bender, just sold by and through them. I am bending 2" x .120 wall tubeing by hand with no problems, I have a 4 foot long cheater bar and its very easy to bend.
    Depdog
  6. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    The link leads to some 'Net Identity' site /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif
    Rene
  7. BIGJ
    896
    Central Arkansas
    vansant
    BIGJ
  8. Depdog
    1,657
    Georgia
    BIG J got it right, sorry I forgot to put the ent on the end of it. /forums/images/icons/crazy.gif
    Depdog
  9. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I used 1.75" .120 wall HREW tubing for mine. And a borrowed Greenlee bender!
