Cage finally done
Discussion in 'The Garage' started by tRustyK5, Sep 12, 2004.
  1. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Finally found the time to finish up my rollcage.
    Also swapped the '74 windsheild frame on, this pic shows the steel pegs I used.
    W/S frame fit and clamped...sorry it's a little dark.
    Rene
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Excellent cage!!!! Now that you're done you wanna make another one just like that and I'll be by here in a bit to pick it up? /forums/images/graemlins/histerical.gif
    Again looks like excellent work and pretty much what I have envisioned us havin when we get around to it.
  3. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Dam Rene that is a nice cage..I want one..And you won't even have to graft the windshield frame..Good work as always , I still need to get up there to pay you a visit...Mike
  4. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Thanks guys,
    The frame was cake when I finally got off my ass and started it.../forums/images/graemlins/whistling.gif
    In a few minutes I'll be attempting to re-install the windshield, then throw the interior back together and put the hardtop back on.
    I still need the 3 hold down brackets that hold the edge of the windshield frame and the leading edge of the topper...gonna post that in the wanted section I guess.
    Mike, C'mon up before the weather gets too crappy./forums/images/graemlins/waytogo.gif
    Rene
  5. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    Looks nice! How much weight do you think that added? Why do all the work to the back part? Is someone going to sit back there?
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    not to shabby, nice desin i like the how the rear comes togeather, you going to put a tire carrier on there someware???
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Bootie Fab /forums/images/graemlins/ignore.gif
    Just kidding man /forums/images/graemlins/bow.gif /forums/images/graemlins/waytogo.gif
  8. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I'll be adding a rear seat mount eventually. So I guess it's "done for now" like everything else. I'd like to bring my girls wheeling and not worry thy're gonna get hurt if things go badly. I'll also need to add some padding obviously.
    Total weight added was approx 250 lbs. There's 110-120 feet of tube in there /forums/images/graemlins/yikes.gif
    Rene
  9. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    kick azz rene!!! is the plan to tie everything into the frame? if so, how does that footing in the center of the body attach to the frame? any pics from below?
    j
  10. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Tire carrier will hold the tire at an angle behind where the rear seat is gonna go. hi-lift will mount on the rearmost leg of the cage on the drivers side (outside of the bar) and a shovel will be mounted on the passenger side rear bar.
    I'm hoping to get the pare in there somehow with a rear seat and still be able to close the tailgate.../forums/images/graemlins/dunno.gif
    Rene
  11. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    j
    No plans to tie into the frame. Thought long and hard and sided with BadDog...tying into the frame is going to create stress risers in the frame. It's designed to flex a little, so I'd like it to. The body is about 200% more rigid now which should help keep the frame from getting too flexy.
    The cage is held down by 28 bolts and 7 base plates (6"x5")right now. The main hoop and 'V' support is bolted through one of the strongest points of the body. That section is boxed and doubled all the way from side to side and has the body mounts directly on the underside.
    The rear bars are bolted through the tailpan. I'm not worried about the cage punching through the floor...on it's lid there would be less than 30 lbs per square inch of pressure on those plates.
    Rene
  12. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Bootie is as Bootie does... /forums/images/graemlins/histerical.gif /forums/images/graemlins/woot.gif
    Rene
  13. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Very nice Rene /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
    Looks like you had to cut up the dash some, especialy the drivers side. Will the factory gauges go back in or do you have other plans? /forums/images/graemlins/peace.gif
  14. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    nice, looks alot like steves cage. /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
    so when you gonna "test" is out /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/screwy.gif
  15. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    wow that looks very stout rene /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  16. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,003
    826
    Pinckney, MI
    Nice work /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  17. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    curious about this as well. Do you think you could have gotten all the tubes in with glass in place and a hard top?
    Damn nice looking though.
  18. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    It looks worse than it is, I only had to cut a small piece from each side. The rest of the 'holes' are factory. The big hole gets filled by the guage panel, and the factory bezel still screws on as well. The top of the factory bezel sits about 1/2" away from the cross tube.
    I plan on a sheet aluminum 'dash' to cover the rest, from the cross bar towards the inside of the truck. The front part of the steel dash on the other side of the bar I sprayed flat black and it can stay that way. I also still have defroster and heater vents.
    I'll snap a few more pic's with the interior back together and of the new windshield frame done (turned out pretty good)
    Right now I'm finishing up installing the windshield. It's in and I'm now fighting the gasket rope thing in all the way around. I'm about 1/4 of the way around and taking a break. I cracked the glass once removing it, and once again putting it back in. Both cracks are not in my eyeline so I might just run it for a while.
    Rene
  19. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    The whole cage was built with the hardtop on and 90% or more was welded before the glass came out. The cross tube messed me up, and I had to remove the glass to weld it all the way around to the down bars. /forums/images/graemlins/doah.gif I also should have pre-painted some sections...
    With some better planning I could do it without removing the glass. In fact I get to put my money where my mouth is because we'll be trying to do just that to my friends 89 Blazer. I had to remove the glass to swap windshield frames anyways...but to have to remove it just for welding purposes would tick me off. It's not a fun job!!
    Rene
  20. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    Sweet! Nice job. /forums/images/graemlins/thumb.gif Looks like a lot of quality effort there. It looks well thought out and nice welds to boot. I hope to get mine started to about two weeks or so. It won't be nearly so complex. Happy rolling! /forums/images/graemlins/peace.gif
