Cage question
Discussion in 'The Garage' started by cegusman, Nov 16, 2005.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What is the minimum cage to head clearence I should try and achive.
    Here is an old pic of the unfinished cage, the area in question is circled.
    I am mounting a set of Corbeau Baja SS seats
    I have about 3" clerence should this be enough? I am 6.2'
  2. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Will you be mounting those seats on the stock frames or building your own seat mount frame/tube?
    Mounting those on the stock setup should give you more than enough clearance.
    Is there an issue about testing the heights?
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    That the whole reason I cut my top off. I am about the same height as you and with a interior cage the bar would be right next to my head.
    My new cage has the bar at about where the stock top used to be. It is probably 6" away from my head at the closest spot.
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I built my seat mounts into the cage and after test mounting the seats I only have about 3" clearence. Thinking on the trail bouncing around I might be hitting my head. I have a friend who is 6.7' and he had about 1/2" clearence before I lowered it about a 1/2". I will look at it some more today and see if I can do any thing else to fix it.
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I am 6'1, just had new seats mounted to the cage and it sounds like I have less clearance than you (can provide pics). I would not feel safe without the seatbelt on but thats not an issue for me anyway. I try to stretch in the direction of the tube with the belt on and I can't reach the tube. I hope this would also be the case in an accident but I would feel better with a harness. After wheeling abit and getting bounced around I have never encountered the cage.... I still plan on putting real roll bar foam tubing - do you know a vendor for that?
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Depends on how tight you keep your seatbelts/harness. You are going with a harness right.?.
  8. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  9. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yes I will be using Corbau's 3 point harness
  10. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    with a regular seat belt, you WILL bounce around more than 3". when i go with a cage I will be using 5 point harnesses. I dont trust the factory belts anyways.
