Cage tubing size?
Discussion in 'The Garage' started by Geargrinder, Feb 26, 2005.
  1. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    So..... what size tube is your'e cage/roll-bar made of?
    I was told that smaller dia. tube is stronger than than biger. If that is the case why not make the cage out of 1" or 3/4"? :crazy:
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    2" is what the main parts of my cage are made out of. Gussets are made from 1", and later I will be adding in some spreader bars of 1.5". Fullsizes are heavy trucks and there cages should be built from 1.75" or 2" tube. 1.5" would be ok if the engineering was good. I would not build a cage with anything less then 1.5" tube, especially for a fullsize.
    1" tube is not that strong. It wold not hold up the the abuse of a rollover. I have kicker tubes on my rock sliders made from 1". I have bent those tubes already and they are supported about every 15" or so.
    Harley
  3. towdriver80
    towdriver80 Registered Member
    Jan 16, 2005
    41
    Maybrook, New York
    what wall thickness do you use?
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    .120 wall
  5. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    Well, the guy that told me that smaller was stronger is in the roundy-pounder field. So I asked him whay he didn't make his chasie out of 1" if it's soooo much stronger than 2" and he said that it "would just look stupid".
    So I'm not crazy for planing to make my tube bed and cage and bumpers out of 2"?
    I'm geting a bender next week and I can only get 1 set of dies for it to start with so I had planed on geting the 2" set 1st.
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    2" tube is easier to get too. All of my main tubes in my cage/bumpers are 2" and you can see pics in my sig.
  7. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I bought a 1.5" die with my bender. I'll be building pretty much everything on my truck, cage included, out of .120 wall 1.5" DOM.
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Interesting....
    Most people with that kind of "advice" are dead already.
    Glad you asked here first. :thumb:
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Could NOT have said it better myself.
    Bending strength increases with an increase in OD.
    Tensile strength increases with an increase in OD.
    Compressive strength increases with an increase in OD.
    He's flat wrong.
    I would venture that 1.75" x .120 wall is the minimum size for cage structure in a K5. Stuff like shock hoops etc. can be smaller. 1.25" x .120 wall is the local favorite size for stuff like that.
  10. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I am going to use 1.75 x .120 for my cage since mine is stripped down to nothing. The design is critical more than if 1.75 or 2" is best
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    1.5" DOM is pretty much a minimum, i wouldn't use 1.5 HREW personally on a fullsize rig. Anything between 1.5 and 2 would work fine assuming its well designed and assembled. For my bender the lone die I have is 1.75. If I need something stronger, I'll just have to suck it up and pay more $ for thicker wall stuff. :)
    j
  12. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Mine is 1.75 .095 wall HREW... that is what is required at the local speedway, so I figured I should be good to go. I have had it on its lid, and it does hold up fine...
