cage ?
Discussion in 'The Garage' started by cegusman, Dec 5, 2005.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    For those that have built there own cage, how many feet of tubing did you end up buying/using. Going to have to redo my cage:mad: . Also please post pics of your cages, I would like to get some more ideas.
  2. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    The 3 cages I built all ended up using around 100' each..
    Pics in my .sig
    :thumb:
  3. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    NO WAY :yikes: What happened?
  4. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Ya whats the deal. You have a bender too?
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Being 6.2' and having a prebent cage is not working out. When mounting my seats, they are allready 1.5" lower than stock and I only have 1/5" of forking clearence above my head and top hoop. The more I lower my seat the less I can see over the hood.
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    No don't have a bender, going to pay a freinds dads shop to do it, They have a computerized bender. I am so forking tired/pissed off at working on the is thing, I would love to just pay someone to finish it.
  7. 81jimmyslt
    Jun 5, 2003
    1,643
    Are you going to use the new ned tech pro program, comes out i a few days I believe? Man I hope I don't run into that problem when I build my cage, I'm only 5'9" but I want to keep my hardtop too!
  8. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Not sure on the program, I am just going to tell them what I want and get some pictures of other cages for example.
  9. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    OH NO. Thats not good. My S&W cage is supposed to come this week. And im 6'1". I hope I dont hit my head, as my seats are in the stock location. Does the cage really take up THAT much room? You said before that your 6'2" and dont have problems hitting your head. Did your head being that close to the cage just get really really annoying after time?
    -Harrison
  10. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    i sat in tim's i am 6' 6" and i hit my head but "tim warned us all that it fits like ****"
    i do want to say the main hoop in his had to be cut to fit
    so i don't know
    but i will make mine because i am taller
  11. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    It's in a Heep, but something like this may give you some more headroom.
    You should be able to gain a few inches in headroom if you make yours similar in that area.
    Another Heep with added headroom
  12. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    If I'm understanding you correctly, it doesn't sound like all is lost.....
    The complaint about clearance is NOT from the main hoop is it? From the looks of it, the problem is that the upper halo is the messing with you....from the drivers seat, it gets awfully close to the left side of your head???
    The problem is that the way most halos attach to the main hoop, forces them to be narrow and they get really close to your head.
    The solution is probably pretty simple:
    Cut out the existing halo and front A-Pillar tubes.
    Bend up a new set of A-pillars that will go from the floor, up past the dash, along the windshield (and slightly ABOVE the upper windshield frame) before making their final bend to allow them to attach to the main hoop.
    If you attach these bars to the horizontal part of the main hoop, you will pick up a number of extra inches over the design you have pictured. You won't have to "Scrap" the entire cage either.....just rework the front section.
    This solution doesn't have a "halo" anymore...it's two long complex A-pillar tubes that would ultimately be attached up front with a bar across the top of the windshield frame. People will argue all day about which style is stronger...but ultimately it has a lot more to do with the quality of the welding, and the gusseting...than the "style" you choose.
    :usaflag:
  13. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I think I used about 110'. My cage is 2" .120 HREW
    I am not finished with it though. I plan on a spreader at the A post, runners between A and B posts, a V in the B post and V or / between B and C posts. I like the full halo it adds a bit of head room.
  14. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    ok I asked this in the other S&W cage post and got no response so... All the cage pics being posted are in full convertables anyone put one in a half cab and if so can in be tacked up and removed to complete the welds and paint or does everything have to be done in place?
  15. 87BrnRsd
    Apr 21, 2003
    2,457
    Great question. I was wondering the exact same thing.
    -Harrison
  16. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    When I did the cage on the '77K5, I mocked everything up and did the welding for the A-pillars and bracing first, then installed the front part of the cage into the truck. Once you weld it to the main hoop, you're committed....Because of the step behind the front seats, you'll never be able to slide it back out once you weld the A-pillars to the main hoop.
    Fortunately, getting 360* welds on the main hoop is pretty easy on a 1/2-Cab if you place the main hoop carefully...
  17. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    The main hoop is also a problem, the way the cage tapers in like this is my problem /-\. My head is only 1/2" away from there too. The whole front of the cage will have to be redone. I plan on doing the main hoop like the pick in the heep. 2 90" bends and strait down to the floor. I also want to rework the back so I have a place for an ice chest.
  18. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Do you plan on running a top of any kind?
  19. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I might make a bikini top. Why do you ask?
  20. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I also plan on doing the halo hoop like this one. Above the window frame. Should give me plenty of room.
