calculating air space
Discussion in 'Audio' started by Suffergauge, Dec 3, 2002.
  1. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    What is the trick to getting it right? I just picked up a pair of mtx 10" subs. Now I need to build a box, just want it to be as close to right as possible.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do you need to know what size box to make?
    If so you need to get that info from the manufacturer.
    Or do you need to know how to calculate the volume of a non-cubical box?
  3. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    How to calculate the volume of the box. So I guess the mathmatical formula.
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It is
    Length * Width * Height
    if it is a cube (measured from the inside of course)
    If it has a wedge type shape when you look at it from the side then
    (top length + bottom length)/2 * width * height
    Make sence?
  5. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    Makes sence to me. Just emailed mtx for the specs. Thanks triaged.
  6. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Should have posted the sub info. I have all of the MTX specs here at work ;-) saved you the time for an email reply.
  7. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Take the external dimensions of the box, minus the thickness of the wood on each side (should be 3/4 inch MDF), take height x width x depth = Z. The measurements should be all in inches. Then you take Z / 1728 = T. And T is the volume of the box in cubic feet...because there are 1728 cubic inches in a cubic foot. Get it???
    Besides subtracting the space that the wood takes up, you'll also want to subtract the airspace that the speaker takes up inside the box (magnet, basket, etc) and any ports if you are using them...bracing too.
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would think that the volume that the speaker displaces would be taken into account by the manufacture when they give out the spec's.????
    If I am going off of the manufactures ###'s do I have to take it into account?
  9. '73 K5
    1,763
    Kansas
    Not all companies do it the same way. JL Audio will give you the internal airspace recommended and also the external dimensions of an example box which takes the speaker volume into account.
    My older Rockford stuff never did that. Somewhere around the Thiele/Small parameters in the owners manual, it would tell you the speaker volume and thats it. When they say 2 cubic feet and means ONLY air in the box. They left it up to the owner to subtract it. If you have the owners manual still it should say somewhere in the fine print.
  10. AudioMaster
    AudioMaster Registered Member
    Jul 26, 2002
    28
    Southern Utah
    What model are they? Do you want a ported or sealed box? Figuring proper box size is very important. MTX should be able to give you their reccomended box for both bass reflex (ported) and sealed boxes. 9.5 out of 10 people will be more than happy with the sound when they build the box to the manu. recommended dimensions. Good luck.
    ~AM
