Calculus Question
Discussion in 'The Lounge' started by 84gmcjimmy, Mar 7, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    What EXACTLY is Calculus? Course selection is coming up, and I need to figure out what courses I want.
    What is it, and what is it used for? (employment wise)
    Thanks.
  2. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Its math. :D
    But seriously, its just another form of math. There are buisness oriented calc classes and then the ones that focus more on the principles of it. Ive taken 3 so far, 2 last semester, both buisness oriented. If your good at math and have pretty good reasoning and logic skills, calc will be a piece of cake. At least it was for me.
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Your taking it in college i'm guessing? because there is only 1 cal. course, and its 1 sememster (5 months) ?
  4. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Its used to find areas, volumes, and find when a varying quanity reaches an extreme value. I would definitly take it if you're planning on going to college.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i took the whole calc package (I-IV and differential eq) back in the day. Basically calc deals with limits and differentiation/integration of functions of one or more variables. When you have a bunch of variables which change with respect to time it comes in really handy. Its really not that hard once you get into the math mindset. I hadn't taken a math class in 4.5 years when I got back into it at community college and you pick it up pretty quick, assuming you're willing to study...
    j
  6. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Calc is very important and is not easy as previously stated. I don't know what business calc is but in the world of enginering calc is no push over. It is really important to get it from day one of calc one.
    I had to take all the way up to calc 4, I did well and it helps me at work all the time.
    I would have to say there is less use for it than I originally thought. I use it for some heat transfer and fluid flow. But I only use it to verify the results that come out of the computer. I could easily get away without knowing it very well, but that could bite me in the ass later on.
    What are you studying in school? What are your future plans?
    -Chris
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    my future plans are in the metal fab. related industry. Either a welder, machinst, engineer, or something a long those lines.
    everyone is saying there is 4 calculus courses? Would it be better to take it after I grad at the local college? Or at school would they do the whole thing?
  8. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I gradeated college without having to take calculus. I did have to take all the algebras and trigs. I hate math but really didn't have a use for cal. in my career. I was an art major with double minors in poly science and foreign language. I hate politics and can't even speak english well.
  9. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    The books and course is just more oriented to buisness logistical problems, its mostly the same material, just presented differently. It turned out to be a waste, since im now going back towards Engineering, i really didnt need them, but oh well, i already took them.
    Steve, are you taking this in a highschool course or college?
  10. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    To be a welder/machinist you probably don't need it. Engineer you definitly will. 1-4 is in college, in high school you get a little of 1 and 2 in the one course.
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I would take it in highschool if I can fit it in.
    84k5,
    So highschool would only have 1-2, then college would have 1-4?
    ahhh!
    Maybe I'll do it twice:confused:
  12. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    No. Highschool will cover *some* of the topics that will be covered in college 1-2, but not all of them. I took it in high school and 1-4 in college. Made it much easier.
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    so you took the highschool version, but also the college version?
  14. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Yeah.
  15. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I have taken calc I, II, & III, plus diff eq (calc on steroids). I think it is a totally awsome way of using numbers (hi my name is Matt, and I am a geek). The basis was from the great mathematician Archimedes (one badass thinker).
    It starts with the area of an unmeasurable object. The circle:) (I know the formula but it came from calculus<- don't make me write the whole proof). If you draw a 4 sided object (square) with all corners touching the inside edge of the circle. Add up the total length of all of the sides and you now have an approximation. Do it with a 5 sided object, then a 6 sided, then 7, then 8, then...... 100....... ect. Well that will get real old real quick (this is how arcemedes found pi [3.14] by hand on a chalk board with a ruler). You will be getting closer and closer each time. Well calculus does this in two steps with a couple of tricks (too hard to explain by typing). And then all hell breaks loose and you press the "I believe" button until it just clicks. Then you get real pissed at people who think we have never been to the moon cause you stayed up all night on a saturday proving it can be done and how long it would take if you could drive your blazer.
    Now, if only linear algebra wasn't kickin' my azz:mad:.
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay I will probably do that too, just for the sake of knowing it.
  17. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    linear algebra is gay. Glad to be done with that one.
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    yikes, Matt, it sounds complicated!
    What is linear alebra? Another college course for your engineer studies?
  19. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Take the highschool class first if you can. It will make life a lot easier on you. It will be an overview at best but is well worth it. I went in w/o any prior knowledge and it cost me a couple of semesters (that and I am a lazy azz)
  20. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Dude after reading that I can feel my brain oozing out of my ear and down my cheek.
