California smog problem
Discussion in 'The Garage' started by hfranger, Dec 8, 2005.
  1. hfranger
    hfranger Newbie
    Nov 20, 2005
    3
    Santa Cruz, CA
    My 86 jimmy is failing the HC when I had it smogged. We tried the standard timing and mixture adjustments. that got it down but not enough. any suggestions?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Maybe lean it out just a tad more, and retard the timing a li'l bit, then as soon as yer done with the smog test bump 'em up. :dunno:
    This is why I got rid of my 81 and 86 and picked up a 73 4x4.
  3. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    :D Get a vin number tag (the whole section in the door frame, :hack: cut yours out and weld :weld:in the whole section it has a false wall inside the tub so after you smooth the welds :grind:and paint it know body will know)and pink slip :deal: from a pre smog vehicle and your all set.:D
    you can build the crap out of the motor and run what you want with no fear from the smog gods.;)
    Not that i would know anybody who has done this before.:whistle:
    This is "informational" only I wouldn't expect anyone to take this suggetion and actually do it.:haha:
  4. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    try...
    Adding some Isopropanol "Dry Gas" will lower hydrocarbons a lot..use 2-3 bottles in a 1/4 tank of gas..Denatured Alcohol works too..That "Gaurenteed to Pass" stuff at parts stores isn't much more than Alcohol and a few other chemicals..it helps too..might lower it enough to make yours pass the sniff test...:crazy:
  5. Bowtie Don
    Bowtie Don Registered Member
    Dec 2, 2005
    5
    San Francisco, CA
    Smog problem
    To the rest of my fellow Californians, there is a little known fact that in MOST of the counties in CA, smog checks are NOT required every 2 years!!! For instance I live in Marin County (just north of San Francisco), and I register all of my vehicles in Lake County (just east of Santa Rosa). To do this I obtained an address from a private parcel post at which point the state of CA only requires ONE smog check for the LIFE of the vehicle!!! So now my two '79 Jimmys, my two Camaros and my Corvette are all registered in Lake County. Haven't done a smog check since. Bowtie Don
  6. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    I knw about the counties that only require smog checks when buying/selling a vehicle. So does your license and have this address on it? Also then do you have the mail forwarded to you or what?? Hows that all work?? You can PM me if prefer to.
  7. Bowtie Don
    Dec 2, 2005
    5
    San Francisco, CA
    CA smog laws
    My CA driver license is NOT in Middletown, (Lake County) it is where I currently reside as required by state law. The Pak 'n Post forwards my mail when I request them to do so, or when I drive up there on a weekend of boating and fishing and pick-up my mail-which is only DMV related. There is no law that says you cannot have multiple addresses or residences. Only that your driver license has your PRIMARY residential address.:wink1: Bowtie Don
  8. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Very interesting.... :thinking:
    The wheels turn slowly but they do turn!!! :grin:
  9. Bowtie Don
    Dec 2, 2005
    5
    San Francisco, CA
    Get those wheels turnin' boy!
    To every dead end we must blaze new trails. To this beaurocractic a**hole I found a butt-plug!!!:D Bowtie Don
  10. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    I have done the same with all of my vehicles. It doesn't go just by Counties but certin areas of counties. They are listed on the CA website. Not only does it help you with a vehicle that doesn't comply, but it saves you time and money every two years. I have 5 vehicles currently registered so it is a significant savings. If you look through my old posts I have several about the subject and some links to the regs. etc.
  11. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    smog
    "This'll be GREAT!" Flounder, Animal House.:bow:
  12. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If your readings aren't too far off now a new cat will do the trick. The cat will also help lower the nox reading.
  13. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    That worked for me also on a '79 Seville, we worked hard to limp thru compliance & the tester reco'd a new cat. Two years later, clean as a whistle. Otherwise, keep two running motors, just swap-in the wimp every two years; probably need to teardown that deep every two years anyway.:D
  14. thfonz98
    thfonz98 1/2 ton status
    Feb 19, 2005
    319
    Salinas, ca
    in my s10(which is now totaled) it read over 1000 on the hydrocarbons, major tune up(included goingt back to stock thermostat, put original chip back in) later 600s, new cat, 8!
