Caliper and pad clocking
Discussion in 'The Garage' started by dremu, Mar 11, 2006.
  1. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Doing the rear disc thing on a 14BFF ... I hate drums, they're heavy and a pain and ... one of my hubs apparently leaked gear oil all over the shoes on that side. :mad:
    So, it makes sense to clock the caliper so that the bleeder screw faces up -- I'm not doing Caddy calipers, I'll do a driveshaft parking brake on this rig.
    Questions:
    1. Do I want the caliper to the front of the axle, to the rear, or does it matter?
    2. The wear tang on the pads goes on the *trailing* edge, yes, i.e. towards the rear of the truck?
    -- A
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    1. Doesn't matter
    2. Doesn't matter
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    The exploded diagrams in the books show which way the wear indicator mounts.:D
  4. dremu
    Feb 27, 2000
    15,954
    445
    I see you went to the same school of charm as Beater_K20. :rolleyes:
    -- A
  5. goldwing2000
    goldwing2000 Guest
    Yep.
    I've seen rear systems with the calipers in front of the axle and behind the axle and I've seen squealers in all locations possible.
  6. dremu
    Feb 27, 2000
    15,954
    445
    Fair nuff. Thanks all!
    -- A
  7. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    The manufacturers do not mount the squeelers in two different positions just because the sky is blue.
  8. goldwing2000
    goldwing2000 Guest
    Ok... so what magical factors are there to consider?
    As long as it contacts the rotor when the pads wear down, what else is there?
  9. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    For us that are looking at them at least once a year (sic) we could probably cut them off or bend it out (Sun. 9:00 PM and wheel is off and I'll stick a screwdriver in there and bend it out to shut it up until Wed.) for all that matters. The fact that all the manufacturers make them that way means that feature is not driven by any one particular make's design, but by industry. Brakes; I'd guess the decisions are driven by product liability. To build in a -1, -2 opposite costs money, and its just pennies per brake set but $$ for the paper in catalog, tracking, inventory, lawyers etc. Engr. wise there's probably a good argument for some abnormal safety scenario like accidents, misalignment, weather etc. Modern cars have crash beams in the doors, its a very small percentage that are ever utilized them, but all the cars have them. In this thread the only reason to try to explain it is because someone asked the question to begin with.
  10. goldwing2000
    goldwing2000 Guest
    Ok, that made absolutely no sense to me.
    Is there or is there not a reason to differentiate putting the squealers in the up or down position?
  11. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Just put the bleeder valve on the high side and you are done....
    If it is not on the high side you cannot bleed the brakes, there's your answer.
  12. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I try to install the squeelers on the leading edge of the pad as it sits on the rotor. The leading edge of the pads usually wear the quickest. Just my $.02
    James
  13. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    true but if its on the leading edge and it contacts it could possibly fold into the pad...
  14. 79Jimmy
    May 10, 2000
    214
    Richmond BC, Canada
    Highly unlikely......those things are usually made of spring steel and would more likely snap than bend. Not saying its not possible but I've never seen it happen. Regardless, at that point its prolly time to change the pads anyway:doah:
    James
  15. goldwing2000
    goldwing2000 Guest
    Yeah... but that wasn't the question. :rolleyes:
    He was asking which way to install the brake pad with the squealer.
