Caliper grinders question
Discussion in 'The Garage' started by Z3PR, Feb 19, 2003.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'll only have a Dana 44 (8 lug). I plan on 15X10 rims with 3.5" back spacing. (Steel rims). Will I need to do any grinding on the calipers ???
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I would say you still have to do a fair amount of grinding.
    -- Mike
  3. Slayer-K5
    Slayer-K5 Registered Member
    Feb 14, 2003
    8
    Davenport, Iowa
    Yes you will, but not very much. I just ground my calipers on my dana 44 for 15 x 10 eatons with 3.5" back spacing and ended up grinding more off the backing plates then the calipers. But in all i didn't have to remove much.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    In addition to this question...I'd like to ask something (sorry, not trying to hi-jack). When you grind the calipers, do you leave them completely mounted - brake hose and all? Do I have to worry about the heat messing up the brake hose or brake fluid...I would think not, but thought I'd ask. Thanks.
  5. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    ditto, i had to "scuff" the caliper and spent more time on the backing plates as well, the freaky thing is that it only hits a little bit, but that little bit locks the tires right up. once i get my motor swap completed, in about 3 hours i hope, then i will be grinding the other side and putting the monster 38.5's on.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    With 4 1/8 b.s. I had to shave a fair amount. These were 15x8. I thought it was only going to be the caliper that needed grinding, but the backing plate needed as much or more then the caliper on my 10 bolt.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I did next to no grinding on my calipers (removed the casting flash and maybe 1/32" on the outsied of the caliper where its strength isn't an issue anyway). I have Eatons with 3.5" of backspacing.
    To get away from grinding on the backing plate I bent the ears down with a 12lb. sledge and then ground the inside of the caliper opening (because it had closed up some and the caliper would no longer fit) till the caliper fit snug but did not hang up. I did most of the work with a file on the calipers and the backing plate! That is how little I had to take off. One of my calipers had lost more meat from rusting (they were rebuilt and sand blasted so there was no rust on them but you could see how deep it had rusted)!
