Caliper grinding
Discussion in 'The Garage' started by BLZN4FN, Jan 16, 2005.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Ok all of you that have a D60 do you regreat grinding the calipers?
    If you were to do it agine. would you do 15,16,16.5 wheels?
    I have read alot on here on caliper grinding just kinda scared to cut into my calipers.
    I need you .02 on this help set me at ease on this..
  2. Chaz Murray
    Chaz Murray Newbie
    Dec 9, 2004
    Stockton Ca
    i have had no problems what so ever with my calipers after grinding...used them for 2 years in the blazer as a daily driver and now the axles out of the blazer are in my comp buggy...i have never gave it a 2nd thought
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    I regret the 2 and a half hours of my life i WILL NEVER GET BACK.:D
    But it is nice to be able to run ANY wheels you want.
    Advise......Get 15's with 2.5" of backspacing. The grinding is nothing compared to wheels with more.
    Rob
  4. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    15's will clear the calipers on 8 lug axles wether its a 10bolt, D44 front OR D60 with stock brakes, without grinding. 15's will also clear a 14 bolt with drums or disc. Its all in the backspacing.
    I run 16's but will be goin 15's. Why? Wider selection of tires, somewhat cheaper..easier to find when you need one.
    16.5" wheels have no safety bead and low pressure will easily unseat a bead.
  5. evo
    evo Registered Member
    Dec 11, 2002
    30
    oregon
    i dont regret grinding mine, havn't had any problems with them, there is still plenty of material there. just takes a while to grind.
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I don't regret grinding mine at all and it's been 2 years and 15,000 miles since I did mine. The only problem I had was I have one oddball rim with .5" more backspacing than the other three. I had ground my calipers for the 3.5" BS rims up front, but when I got new swampers the oddball rim ended up on the front of the truck.
    I took it for a test drive and it steered fine, didn't pull, didn't make any noise...but within 3 miles the bead area of the rim got red hot and the tire blew as I was pulling a U-turn. I got stung by a series of werid circumstances, but it does show that giving each tire a good spin by hand before letting the jack down is a good idea.
    Anyways, braking performance has been fine and haven't had any other problems.
    Rene
