Caliper hanging up and pulling to the right?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyfumes, May 12, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    If it's pulling to the right what side is sticking and whats the easiest way to fix it, do I have to take the caliper apart and tbleed the brakes after, because I'm just too damn lazy right now for that hehehehe?????
  2. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Pulling to the right....right caliper is hangin. Remove the wheel, remove the caliper with lines still attached, WD40 the piston(s) and use a clamp w/ wood piece to get the caliper pistons to bottom out back inside the cylinder. Brakes...pistons back out...clamp, pistons back in....spray...in...out...spray...all better.
  3. dyeager535
    26,982
    191
    I had to sand whatever crap was on the rotor off, and replace the pads, before my truck would stop pulling. It may not be your resolution, but pulling the tire off will tell you for sure. I assume mine was grease though, and the "bumps" created by the burnt on stuff would not allow good braking on the side that WASN'T pulling.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Hopefully its something simple. Could even be your old brake lines expanding under force. But even rear drums that arent hitting at the same time (or the same force) could have negative results.
    Mine were just from the fact that I let one side wear all the way down to the rivets! I got two large groves, but.. oh well! I just tossed on new pads, The'll wear down over time. /forums/images/icons/wink.gif
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Pulling to the right could ALSO mean that the left caliper piston is sticking and not engaging the disc. No breaking on left = pull to the right. One way to hceck is to get some needle-nose vise grips. Pinch off your left side line and drive down your street and try to stop. See if it pulls to the right (it should). Also see how well it stops. Then, pinch off the right side line and do the same thing. Whichever side DOESN'T pull is probably the culprit. That means that caliper is sticking and not engaging the disc. If both sides pull, but one doesn't seem to release as you let off the brake, it could be sticking and the caliper not RELEASING the disc.
    Just a few things to try. But, if you are going to simply try and WD-40 the caliper piston, why not do both sides. I am sure it couldn't hurt. I plan to do mine this weekend.
  6. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Hope it's an easy fix. Mine STILL pulls to the right after peplacing front and rear brakes (calipars, cylinders, drums, rotors, everything) new ball joints, alingment, and rotate the tires. I'm confused. Maybe all the roads around here really slope one direction /forums/images/icons/smile.gif
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    eep, if its still pulling after that... Acutally wait a second, mine pulls to the right!!! Sometimes it could be the slop of the tie rod ends (but you said you replaced those).... do you get better brake response if you hit the brake quickly, rather than pressing it slowly?
