caliper info needed for disc brake swap.
Discussion in 'The Garage' started by ryan22re, Oct 4, 2005.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i see two front brake caliper sizes listed in the catalogs for the 3/4 tons. the sizes listed are 2 15/16" and 3 5/32". i only see one rotor listed. quick call to carquest confirms it. the larger caliper uses the same rotor/bracket, just a bigger piston.
    i would assume that the larger caliper could possibly use up too much brake fluid resulting in a squishy pedal. the smaller calipers prob would offer a firmer pedal. no real difference in price. or did the carquest guy steer me in the right direction. any ideas or opinions on this?
    ryan
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I didn't know there was two different ones. I just got the rotors, callipers, and pads to fit a 77 3/4 4wd. At advance its was like $20 each rotor, $15 each calliper, and a set of $18 pads.
  3. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    used 1/2 ton front calipers on my truck 6500lbs and 1 tons with 38" tires. no stoping problems.
